intermittency of transition SST model
Old   August 29, 2013, 11:20
Default intermittency of transition SST model
steven
steven1 is on a distinguished road
In my case, i want to use the transition SST model or the transition k-kl-omega model. But i don't know how to determine the intermittency and the laminer kinetic energy.
Does someone know how to calculate them?
Thank you.
Steven
steven1 is offline   Reply With Quote
Old   August 29, 2013, 13:05
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You dont need these quantities.
Far is offline   Reply With Quote
Old   August 30, 2013, 03:20
steven
Thank you for your reply.
So what should i fill in the blank?
Old   August 30, 2013, 05:24
Far
Sijal
Are you talking about transition models of Fluent? If yes then you dont need to input any parameters for these models except turbulence length scale and turbulence intensity if you have info about them.
If you dont have info about length and intensity then you can use these parameters (can be used in parametric study) :
For turbulence length scale you take it as 30% of chord length and turbulence intensity can be taken as < 1% for low distrubence such as in wind tunnels, 1-5% in normal free stream conditions and >5% in highly disturbed upstream flow.
Old   September 2, 2013, 07:59
steven
Ok, thank you, so i can i will have a try.
Old   September 2, 2013, 08:44
steven
hello, i still have a question. how can i judge whether my results are correct? for example, when i use k-epsilon standard-wall function, if my yplus are between 30 and 300, i'ill accept the results.
Thank you.
Old   October 23, 2017, 18:28
arohr is on a distinguished road
Hi Far,
I know I'm bringing up a very old post but this one is the only thread which directly has my question in it.
I am in search of the literature or direction from the solvers on where the relations of turbulence length scales is described. I am trying to use the transition-SST 4 equation model and want to make sure I am inputting reasonable values for length scale (my flow generally boils down to a cylinder in cross-flow).
In fluent's user's guide I see they bring up a relationship of 0.07*L for length scale, where L is characteristic duct size. I am hesitant to use this because my overall analysis is a free shear flow. I am also dealing with a very large Reynolds (on the order of 10^5) and am hesitant to use values meant for wall-bounded flows.
The experiment I am comparing against gave me turbulence intensity of their tunnel so I don't need to worry there. Any help would be greatly appreciated.
arohr is offline   Reply With Quote
Old   October 24, 2017, 02:56
Far
Sijal
What i have learned is that "Length scale has minimum to no effect on transition"
Rule of thumb is to take length scale = 0.3 L.
Or you can hit & trail and check it.
turn off wall functions in Transition SST model? johnp FLUENT 11 May 26, 2020 13:57
SST Transition model in Fluent 12.0 Far FLUENT 1 November 8, 2010 01:32
Missing Information in SST Transition Model Formulation Josh CFX 2 September 14, 2010 11:49
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
expert parameters of SST model? David CFX 1 December 2, 2005 06:36
