Regarding Species Transport for Diffusion
Old   September 8, 2013, 01:12
Default Regarding Species Transport for Diffusion
chia chun
kayne91 is on a distinguished road
Hi there,
I am trying to simulate an ion diffusion process through a nano-channel using Species transport model. I have created a mixture of CO2 and water with water being the bulk species and set up a concentration gradient of CO2 across the top (inlet) and bottom (outlet) of the channel. The inlet velocity is set to 0 as i do not want any convective fluid flow, only pure diffusion.
When i run the process, i realised that both CO2 and water are diffusing through the channel at the same time (which is expected). My main concern is how do i allow only CO2 to diffuse through while making water as the background stationary fluid in the channel where CO2 will travel.
Does anyone know what should i change in the setup?
I tried removing water from the species mixture, leaving only CO2. but by doing so, i could not set up a concentration gradient under the boundary conditions of inlet and outlet.
Can anyone provide some advice here? Thanks in advance!
kayne91 is offline   Reply With Quote
Modelling Biomass Combustion via Species Transport Racheal FLUENT 39 January 8, 2022 07:42
Fixed Bed Gasifier, Species Transport Problem therandomestname FLUENT 12 January 4, 2019 07:08
Please help!! Patch and Species transport Julie FLUENT 5 August 3, 2016 03:10
questions about species transport through walls shuqin FLUENT 13 April 9, 2014 02:42
Implement species transport equation Tobi OpenFOAM Programming & Development 0 June 2, 2012 13:26
