Can't Update FLuent Setup with active Connections in Mesh
Like Tree1Likes
  • 1 Post By pieczareks
Old   September 12, 2013, 06:48
Default Can't Update FLuent Setup with active Connections in Mesh
Sabine Müller
dulka90 is on a distinguished road
i have a Problem with my model. (Working with Workbench and Fluent)
When i normally aktivated my Connections in the mesh i cant go forward to the Fluent Solver. It cames a Error:
"Update failed for Mesh component in ***. Error updating cell Mesh in system ***. View the messages in the Meshing editor for more details."
and when i look there i find the message:
"The mesh file exporter failed during translation. Please send your data to your support provider."
So ill tried to suppres all connections, its working then, but my problem is i need the connections for the heat transfer.
So i looked thrue the connections and found some which are "unrealistic" so i went down with the tolerance value. Now there are only connections wich are realistic.
But i cant open fluent either. If i only aktivate a few connections it works, but then i get the message in fluent when i initialize that "Interface zones overlap for mesh interface ***. This could adversly affect your solution."
Ans then when i try to look up the boundary Conditions Fluent shuts down.
The mesh consits of round about 5 million elements.
Does anybody know the problem, or have a idea why it behaves like that?
Thank you very much in advance.
dulka90 is offline   Reply With Quote
Old   December 6, 2013, 08:31
Rafal
pieczareks is on a distinguished road
I had same problem. To solve it, the entire path to the file of the project, together with all the names in your project folder should not contain local characters and spaces. Example:
E:/homework/work-1/files/projectname/example.msh
The next thing is to go back to version 12.1 of Ansys, and this is all.
If you see the following message:
"The mesh file exporter does not support overlappiing geometry in named seletions",
must correctly name all the elements of the grid, before it goes up for Setup/Fluent. But is not necessary. Example: inlet, outlet, wall, fluid.Try not to use own names.
villager likes this.
pieczareks is offline   Reply With Quote
Old   December 6, 2013, 11:59
Sabine Müller
If spaces or something else in the path-name would have caused the problems i would have found that i proofed that ... and now spaces or local characters were in it .... so that wasnt the problem ... and never had the other message
so still dont know what was the problem ...
Old   December 6, 2013, 13:00
Rafal
Do you have same problem in Ansys version 12.1? Install it pls.
Old   December 7, 2013, 05:58
Sabine Müller
I cant try it now anymore
I had only the license during my bachelor thesis ...
Sry ... but if i ever have the problem again (in march/ april) i start the next simulation project ... then i may can try it ... but not at the moment
Old   December 7, 2013, 07:54
Rafal
Try to find version for noncommercial use only.
Old   December 7, 2013, 09:04
Sabine Müller
doesnt excists There are no noncommercial versions of Ansys ...
Old   December 9, 2013, 08:10
Rafal
So i dont know what is this:
http://www.youtube.com/watch?v=yxG1POOgI8A
Old   December 9, 2013, 11:36
Sabine Müller
ok ... i should better say, i cant find it ... i dont find any side where i can get a ansys fluent license for only noncommerial purpose ... they excist ... ok ... but where can i get it? ... One month ago .. i surfed the internet ... but nowhere i found something ....
connection, contact, mesh, update
[ICEM] Using Surface Mesh from ANSA for Fluent Sim tommymoose ANSYS Meshing & Geometry 15 March 3, 2016 17:29
[ICEM] Missing face error from FLUENT even after repairing mesh + other questions unknown159 ANSYS Meshing & Geometry 0 July 5, 2013 20:18
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
Moving mesh in Fluent fivos FLUENT 0 April 2, 2010 09:45
