Heat transfer through a pipe located within the soil.
Old   September 13, 2013, 08:17
Default Heat transfer through a pipe located within the soil.
Rohit Tripathy
Rohit Tripathy is on a distinguished road
I have to simulate the heat transfer occuring as a result of forcing air through the pipe of an Earth air heat exchanger tube. The surrounding soil is to be assumed as a heat sink .
What are the boundary conditions that i should use to correctly simulate this case ?
Rohit Tripathy is offline   Reply With Quote
Old   September 17, 2013, 01:22
AKHILESH S L
AKHILESH S L is on a distinguished road
u can use velocity inlet for the air flow in the inlet side. i think so
AKHILESH S L is offline   Reply With Quote
Old   September 17, 2013, 01:35
Rohit Tripathy
yes i know that..but im having trouble with the boundary conditions modelling the heat transfer
Old   September 17, 2013, 04:14
AKHILESH S L
can you please give a detailed quote of your problem? let me see if i can help...
Old   December 5, 2013, 01:45
Kumudu
Kumudu is on a distinguished road
Have u able to sove your problem?.I have to solve the same kind of problem, but my heat exchanger is circulated with water. But, geometry would be the same. Can u tell me how you use boundary conditions?. Which solver u used for this.
Thanks
Kumudu is offline   Reply With Quote
fluent 12.0, heat transfer
Heat transfer through pipe wall billue123 FLUENT 4 June 5, 2013 03:15
The process of heat transfer. Pipe in Pipe hottern CFX 5 June 30, 2011 03:45
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Heat transfer to fluid and pipe body Chris FLUENT 1 December 28, 2002 02:09
