how to read a 3D trajectory for CG_MOTION
Old   October 3, 2013, 05:29
Default how to read a 3D trajectory for DEFINE_CG_MOTION
Francisco
Bollonga is on a distinguished road
Hi everybody,
I'm using a UDF with DEFINE_CG_MOTION to define the movement of an object in a 3D fluid domain. The path followed by the object is an irregular path so I wonder if there is a way for the macro to read a vector of positions instead of a mathematical description?
Thanks a lot
Bollonga is offline   Reply With Quote
Old   October 5, 2013, 13:38
like.no.other
like.no.other is on a distinguished road
Hi
You can do this with a profile
It is very simple
www.CFDiran.ir
like.no.other is offline   Reply With Quote
Old   October 5, 2013, 13:40
Francisco
Originally Posted by like.no.other View Post
Hi
It is very simple
Could you please explain me how to use a profile? Thanks a lot!
Old   October 5, 2013, 14:12
like.no.other
first you should create a file with prof extension (*.prof) like the attached picture.
in profile you can define the time dependent variables (v_x,v_y,v_z,omega_x,omega_y,omega_z)
for example in this profile the angular velocity in z direction is defined.
at the end you should read it in fluent.
www.CFDiran.ir
Old   October 7, 2013, 07:25
Francisco
Thanks a lot! You've been of great help!
Old   August 18, 2014, 06:45
Francisco
What happens when the profile timestep is larger than the solver timestep? Does it linearly interpolate the position between the two profile timesteps?
Any help would be greatly appreciated. Thanks.
cg_motion, dynamic mesh, macro, moving mesh, udf
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 UDS_rambler FLUENT 2 November 22, 2011 09:46
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
