Urms of Vertical Velocity
Old   November 28, 2013, 04:38
Default Urms of Vertical Velocity
hct
hct is on a distinguished road
I am running a steady state CFD of windflow over a process plant.
I would like to track the root-mean-square of vertical velocity or the standard deviation of vertical velocity fluctuations in FLUENT.
However, there is no such option in FLUENT.
Since we know that
U'=√(1(u_x'^2+u_y'^2+u_z'^2)/3)=√(2k/3) , where k = turbulent kinetic energy
and that for RANS model (what I am using) assumes isotropic reynold stresses (where u_x'=u_y'=u_z') , we can come to the following formula,
√(1(3u'^2)/3)=√(2k/3)
k=3u^2/2
Which means that if i am looking for a standard deviation of vertical velocity fluctuation value of 1.75m/s, I can look for a value of 4.59 J/kg in the turbulent kinetic energy plot.
Am I interpreting this correctly?
hct is offline   Reply With Quote
Old   December 5, 2013, 02:48
hct
Anybody can help me on this?
Old   December 6, 2013, 11:10
Jamal Foroozesh
jamalf64 is on a distinguished road
You must run your simulation unsteady. in unsteady problems, fluent have Urms in "unsteady statistics" option.
I hope this help you.
Best Regards
Jamal
jamalf64 is offline   Reply With Quote
Old   November 17, 2014, 10:51
Default hi
Qureshi M Z I
m zahid is on a distinguished road
i want to calculate the Reynolds stresses (space averaging) at steady state . if any body know the steps in fluent or any book and reference material. please share this.
thanks
regards
m zahid is offline   Reply With Quote
Old   November 17, 2014, 13:19
danielfc is on a distinguished road
hct,
Maybe it is too late to help you, but considering your question, it seems like you are dealing with helideck design, since CAP437 recommends a maximum vertical velocity standard deviation criterion of 1,75m/s.
Your interpretation of the kinetic turbulent energy is reasonable and I have used the same approach in the paper OMAE2010-20686, including comparisons with experiments. My advice is to use this simplification carefully, since it gives you a good overview of the turbulence field, but it may result in large errors if considered locally.
danielfc is offline   Reply With Quote
Average velocity of two different planes niqbal OpenFOAM Post-Processing 6 June 19, 2017 06:08
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
Problem with time average tangential velocity in swirl flow. lakhi FLUENT 5 July 18, 2012 16:28
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
