Solution initialization accuracy initial values
Old   December 5, 2013, 13:54
Post Solution initialization accuracy initial values
Paja
paja123 is on a distinguished road
in solution initialization, when I set up to compute my initial values from my velocity inlet, I see the table of initial values with little bit different values. For example I used velocity 10m/s and there is 9,999993 m/s, the same with temperature I set up 293 K and there is displayed 292,9999 K.
Does someone know why? Should I correct the accuracy somewhere?
Thanks!
Paja
paja123 is offline   Reply With Quote
accuracy, initial values, solution initialization
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Why RNGkepsilon model gives floating error shipman OpenFOAM Running, Solving & CFD 3 September 7, 2013 08:00
why divergence occures in these cases immortality OpenFOAM Running, Solving & CFD 2 January 25, 2013 10:21
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 05:36
