December 7, 2013, 06:44 |
Iterations and Residuals
Tom Marquardt
Rep Power: 13 |
Hey guys,
I'm simulating natural convection of a melting phase change material in a vertical cylinder. A hot water stream heats up the solid PCM around. My problem is, if I leave the residuals at default settings (10e-3 and 10e-6 for energy) for a time step calculated by the rule of thumb of Ansys, the solution converges after a while for the first Iteration and as a result there is no big progress in the simulation. If I force Fluent to iterate each time step with 20 Iterations the result is totally different, the melting goes much faster. Do I have to change the residuals to a lower number or what would you guys suggust? I'm a bit lost here |
plot residuals in multiregion solver | val46 | OpenFOAM | 4 | December 12, 2016 06:06 |
Omega goes infinity | callumso | OpenFOAM Running, Solving & CFD | 5 | October 2, 2013 07:52 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 00:36 |
