Error in initializing solution (invalid float) |
December 10, 2013, 09:23 |
Michael
Rep Power: 12 |
Hi everyone!
I am currently analyzing an airfoil on Fluent (incompressible flow). When initializing the solution I get this error: Error: Domainvar_Get_Float: invalid float Error Object: -1.#ind I don't know what it means. I saw a topic of 2005 saying that it was probably the boundary conditions or the mesh but I don't see what is wrong in my case. My mesh consists of an inflation (smallest layer about 1e-7 m) and triangles around. My BC are simply the lower and upper sides of the airfoil which are considered as walls (no slip, etc), a farfield with a gauge pressure of 95000, M=0.28, Xcomp= 0.99963, Ycomp= 0.02705 and I also have two other BC ("fff-surface" and "interior_fff-surface") that I suppose come from the geometry that I created during the first stage in space claim and are defined as an "interior" type. Can you help me? cheers! |
December 10, 2013, 11:38 |
Alex
Rep Power: 47 |
What is the output when you click on "mesh->check" ?
December 11, 2013, 11:05 |
Michael
Rep Power: 12 |
Hi, thanks for the reply!
Here it is: Domain Extents: x-coordinate: min (m) = -3.999947e+01, max (m) = 4.000050e+01 y-coordinate: min (m) = -3.897546e+01, max (m) = 4.097702e+01 Volume statistics: minimum volume (m3): 3.381924e-10 maximum volume (m3): 1.471395e+01 total volume (m3): 5.021998e+03 Face area statistics: minimum face area (m2): 5.555087e-07 maximum face area (m2): 6.414105e+00 Checking mesh................. WARNING: The mesh contains high aspect ratio quadrilateral, hexahedral, or polyhedral cells. The default algorithm used to compute the wall distance required by the turbulence models might produce wrong results in these cells. Please inspect the wall distance by displaying the contours of the 'Cell Wall Distance' at the boundaries. If you observe any irregularities we recommend the use of an alternative algorithm to correct the wall distance. Please select /solve/initialize/repair-wall-distance using the text user interface to switch to the alternative algorithm. ........ Done. I don't know why it says something about "volume area" because I am working in 2D. And then well it is just a warning. I used high aspect ratio cells (quadrilaterals) for the boundary layer, I think it is a correct algorithm... |
December 11, 2013, 11:12 |
Michael
Rep Power: 12 |
BTW I also noticed that my orthogonal quality is very low: 4e-3.
But my mesh is alerady extremely refined around the airfoil: The "element size" is about 2e-3 m My first layer thickness around the airfoil is 5.5e-7 m Only the farfield has cells of size 6 m (but they are at 50 or 70 m from my airfoil so I don't think it is a problem...). |
December 11, 2013, 11:29 |
Alex
Rep Power: 47 |
Concerning the high aspect ratio cells, this is a common warning message for simulations at high Reynolds numbers. Nevertheless, I recommend that you do what the warning message says and have a look at the cell wall distance computed by fluent.
You might simply produce a xy plot of the cell normal distance along the wall. Never mind the "volume" statistics for a 2d mesh, the output is always the same no matter if the mesh is 2d or 3d. Since your mesh quality is extremely low, you should consider that this might cause the errors. Keep in mind that a "fine" mesh does not equal a mesh with good quality. With some pictures of the mesh and more info on how (which software, settings) it was created we should be able to give you a hint on how to improve it. Since you get the error on initialization: is there anything special about your initialization values? Do you still get the same error when using a velocity boundary condition instead of the far field bc? |
December 12, 2013, 05:09 |
vidyanand
Rep Power: 17 |
this error we got usually for boundary condition, please check the bc and units, sometime i face the problem in periodic model, try to use smooth and swap option to increase the quality
December 13, 2013, 05:43 |
Michael
Rep Power: 12 |
I uploaded some pictures. I also tried to do as the warning says but: 1/ I cannot compute the cell-wall-distance because to do so I need to initialize the solution (with standard values). But when I do that I get the same error of invalid float... 2/ I entered solve/initialize/repair in the text user interface. But it said that wall distance repair wasn't needed. Here is what I got: > / solve initialize repair-wall-distance repair-wall-distance doesn't seem to be required; proceed anyway? [no] yes Enabled correction of wall distance at high aspect ratio quadrilateral, hexahedral, and polyhedral cells. Warning: compute-wall-distance: wall distance not required by enabled models. I don't think my values for the initialize have something special. I just say "standard initialization" and compute from "farfield". The values are automatically set up. And well for the BC I cannot use a velocity BC because my domain is a sphere so I cannot really set somethine like inlet/outlet (if that is what you mean). My BC are quite simple actually. The detail of them is in my first post, but tell me if you need to know somehting else! As for the software I used "ANSYS meshing". What I did is: 1/ upload the airfoil with the domain (from spaceclaim, which is like Design Modeler). My arifoil is surrounded by two quadrilateral domains. I also added straight lines at the trailing edge to divide it in several sections (easier for inflation). You can see it in the pictures. 2/ Set up a method with triangles 3/ Set up two "Sizing" around my airfoil to get more accurate data (elements of size 2mm and 5 mm) 4/ Set up an inflation to capture the boundary layer. My first layer is about 5.5e-7 mm and I have 70 of them with a growth ratio of 1.1 Mesh1.jpg Mesh2.jpg Mesh3.jpg DomainAroundAirfoil.jpg TrailingEdge.jpg Thanks a lot for your comments! |
December 13, 2013, 05:55 |
Alex
Rep Power: 47 |
Are you using double precision in Fluent? I highly recommend that.
December 13, 2013, 06:10 |
#9 |
Rep Power: 17 |
Double Precision!
But your quality is poor! Enhance quality and try again |
December 13, 2013, 07:48 |
#10 |
Michael
Rep Power: 12 |
Why do you mean by double precision?
And how do you see that my quality is poor? Is it because of the huge cells far from the airfoil? |
December 13, 2013, 09:38 |
#11 |
Michael
Rep Power: 12 |
Or maybe this part is not very good (see attached picture)... I removed some lines at the TE (now I only have two, starting at the vertical part of the TE) because I had some problems with the inflation.
When I click on "meshing" this is what I get if I zoom on the TE: TrailingEdgeMesh.jpg When I check my mesh quality, it says that the minimum orthogonal quality is about 5e-3 (which is too low). I think it comes from this part of the mesh. Is that what you were refering to whan you talked about my mesh quality? But then I am not really sure how to improve that, the TE is what it is... the sharp angle ("bottom" of the TE) is always going to be there. |
December 17, 2013, 06:12 |
#12 |
Michael
Rep Power: 12 |
Well in the end I think I fixed the problem.
I just set the Flow Courant Number to 1 (it was set to 5 before) and I also ticked the box "pseudo-transient" which is recommanded when you have high aspect ratio cells. Then I just set up the length scale to 1 (length of my airfoil). And it worked! The solution converges where what seems to be proper values. Thank you for your help, all of you! |
error, float, fluent, initialization |
CFL Condition | Matt Umbel | Main CFD Forum | 19 | June 30, 2020 08:20 |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
Problems building Paraview 3.12 on Gentoo Linux | pajot | OpenFOAM Installation | 11 | April 11, 2013 08:09 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
