porous surface in a room
Old   December 17, 2013, 05:59
Default porous surface in a room
tmeysam92
tmeysam92 is on a distinguished road
Hi
There is a porous surface whose fluid porosity is 0.2337 and air is passing through the surface. What I should put for viscous resistance in fluent?
Is there any formula to calculate it?
Regards
tmeysam92 is offline   Reply With Quote
Old   December 18, 2013, 07:08
OJ
oj.bulmer will become famous soon enough
You would need some data that would give you a relation between pressure drop at different flow rates. You can then devise the loss coefficient from this and plug the values in porus jump boundary condition. The procedure is very well documented in the Help documentation.
oj.bulmer is offline   Reply With Quote
Old   December 20, 2013, 04:37
ethen
skikay is on a distinguished road
Darcy law to calculate
skikay is offline   Reply With Quote
fluent 14, porous body
[ICEM] Surface mesh not sticking to surface holtwong ANSYS Meshing & Geometry 2 April 20, 2023 08:28
surface reaction, porous media Ali FLUENT 2 March 31, 2016 17:26
[snappyHexMesh] Snap Precision to a STL Surface malaboss OpenFOAM Meshing & Mesh Conversion 16 July 26, 2013 01:44
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
how to set no-slip on the surface of porous media Nanjiang FLUENT 0 August 7, 2007 13:15
