FLUENT 14.5 parallel processing on network of computers
Old   December 20, 2013, 02:14
Default FLUENT 14.5 parallel processing on network of computers
yehanyu
yhy20081016 is on a distinguished road
Hi, everybody. I am currently using ANSYS FLUENT 14.5. I want to perform parallel processing on a network of two computers. Both computers are running Windows 7 operating system. Since there are only two computers, router is not used, and the two computers are directly connected by an RJ-45 wire. The connection of the two computers are already verified by the "ping" command. I am currently using Intel MPI (In FLUENT Launcher, the "MPI Types" option is set to "intel".). However, it doesn't work. The error message is shown as follows:
Unable to connect to 'a1:8678',
Does anyone know the solution? Thank you very much.
yhy20081016 is offline   Reply With Quote
Old   April 16, 2014, 05:55
Question
mariachi is on a distinguished road
Hi yehanyu !
I think i'm going through the same problem. You must have found a solution by now. Can you share?
mariachi is offline   Reply With Quote
Old   April 16, 2014, 23:10
yehanyu
Originally Posted by mariachi View Post
Hi yehanyu !
No, I haven't found the solution yet.
Old   April 17, 2014, 04:18
Thanks yehanyu! I guess you are managing with a single PC then..
Old   May 7, 2014, 03:49
See here:
http://www.cfd-online.com/Forums/flu...tml#post488458
Old   May 8, 2014, 03:19
yehanyu
Thank you very much. I will try it.
Old   May 20, 2014, 06:36
Default same problem
cfd
omid8 is on a distinguished road
hi
i have the same problem
should the username of two computer be same?
please share the solution if anyone find answer.
thanks
omid8 is offline   Reply With Quote
Old   April 6, 2018, 03:33
Payar Radfar
PayarRadfar is on a distinguished road
Someone found a solution? I have tried that and did not work i get an error.
and let me know if I can do it on uni computers in computer lab considering the network at uni ? Cause someone did it last year but no one knows how to do it now !
help please
Best Regards
Payar Radfar
Payar.Radfar@gmail.com
PayarRadfar is offline   Reply With Quote
Old   April 6, 2018, 14:28
Lucky
help please
There's a tutorial by Daniele.
You do need sufficient privileges to launch programs on the other machine.
Old   April 6, 2018, 20:47
Payar Radfar
Hi
Thanks for the reply.
Yes I have done that. However, it does not work. Fluent gives an error in the command
Best Regards
Payar Radfar
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
Fluent Parallel Processing Issue Vijay FLUENT 1 January 25, 2012 09:55
Set up parallel processing Fluent 6.3.26 ibex7 FLUENT 2 January 15, 2010 07:11
Parallel Processing by FLUENT? M Kermani Main CFD Forum 2 February 21, 2001 10:01
