Can fluent get the lift and drag coefficients of the two walls (in different directio |
January 8, 2014, 05:59 |
yu. yuxuan
Rep Power: 12 |
There are two walls wall1 and wall2.
wall1 z-axis direction, wall2 x-axis direction. I use {monitor-force}. After the calculations and I found that only get wall2 lift and drag coefficients. That means when I set, the wall2 settings cover the previous settings so I want to know can fluent get the lift and drag coefficients of the two walls , thank you. |
January 8, 2014, 07:48 |
Maxime Perelli
Rep Power: 41 |
Define 2 monitorings: one for wall1 and one for wall2
In memory of my friend Hervé: CFD engineer & freerider |
January 8, 2014, 19:09 |
yu. yuxuan
Rep Power: 12 |
January 9, 2014, 00:45 |
Maxime Perelli
Rep Power: 41 |
Monitoring Forces and Moments on Individual Walls
By default, FLUENT will compute and monitor the total force or moment for all of the selected walls combined together. If you have selected multiple walls and you want to monitor the force or moment on each wall separately, you can turn on the Per Zone option in the Force Monitors panel. The specified force vector or moment axis will apply to all selected walls. If the monitor results are printed to the console (using the Print option), the force or moment on each wall will be printed in a separate column. If the results are plotted (using the Plot option), a separate curve for each wall will be drawn in the specified plot window. If the results are written to a file (using the Write option), the file will be in a tab-separated column format based on the XY plot file format described in Section 28.8.5. https://www.sharcnet.ca/Software/Flu...049.htm#179853
January 9, 2014, 05:07 |
#5 | |
yu. yuxuan
Rep Power: 12 |
The lift direction of wall1 is z-axis . while the lift direction of wall2 is x-axis . So if I choose two walls, it shares the same force direction,right? Then if I put (0,0,1) in {Force vector} . Does it change the force direction of wall2 into z-axis? |
January 9, 2014, 07:17 |
Maxime Perelli
Rep Power: 41 |
ok I understand
Then you can try to define 2 monitors by clicking "Apply" once one monitor is well set Remember to click Apply after making the desired modifications to the setup for each coefficient report.
January 10, 2014, 06:29 |
yu. yuxuan
Rep Power: 12 |
January 10, 2014, 06:58 |
Maxime Perelli
Rep Power: 41 |
then I don't know since I don't have Fluent
January 10, 2014, 20:13 |
#9 |
yu. yuxuan
Rep Power: 12 |
fluent 6.3.26, lift and drag, two geometries |
direction vectors for lift and drag in fluent | nauman55 | FLUENT | 7 | September 23, 2020 14:47 |
calculating drag and lift in fluent | morteza08 | FLUENT | 4 | December 13, 2012 15:34 |
Great lift coefficients but negative drag coefficient?! | nez | FLUENT | 0 | November 28, 2011 13:57 |
How does FLUENT calculate lift and drag? | xTamx420 | FLUENT | 0 | May 30, 2011 13:35 |
Lift and Drag Coefficients Reliability | Luis | FLUENT | 2 | December 27, 2005 14:45 |
