fluent continuity convergence problem
Like Tree1Likes
  • 1 Post By sampathevs
Old   January 9, 2014, 22:23
Default fluent continuity convergence problem
pibea is on a distinguished road
Hello all,
I have convergence problem in continuity...
it's very simple geometry but it is not converge.
My geometry is rectangular duct with partially supplying constant heat flux in 2D.
I used coupled solver.
I think mesh quality and boundary condition are not wrong.
I don't know why this problem occurs.
pibea is offline   Reply With Quote
Old   January 9, 2014, 23:20
EMAVI V SURYA SAMPATH
sampathevs is on a distinguished road
what is your outlet condition ? if its outflow, try changing to pressure outlet.
and, check your convergence based on mass balance or any other parameter. don't base only on residuals.
sampathevs is offline   Reply With Quote
Old   January 9, 2014, 23:21
also, try reducing the URF's of energy, momentum to 0.4...
pressure URF increase to 0.6
post the update if you try these..
genaro likes this.
Old   January 9, 2014, 23:46
Default Hi sampathevs, Thank you for your reply:D
In my geometry, I used pressure outlet and its pressure is 1bar.
I change the URF as you recommanded and residuals look more stable.
Mass flow rates of inlet and outlet are almost same and other parameters are normal, I think.
Then, can I think this case is converge although continuity residual is about 8*10^-1?
Old   January 10, 2014, 02:13
i suppose, yes.!!!
Old   January 10, 2014, 06:51
Bharath kumar
bharath is on a distinguished road
hi pibea,
I think there may be some basic mistakes may be there.
1. Please check your scale of the mesh.
2. Try first K-epsilon model then switch to RSM (first order).
3. Post some pics to under stand better
bharath is offline   Reply With Quote
Old   January 10, 2014, 20:54
hi bharath,
thank you for your reply.
I did not quite understand 'check scale of the mesh' in your reply.
Could you please explain that more?
Does scale of the mesh mean mesh quality?
Old   January 10, 2014, 22:30
kad
kad will become famous soon enoughkad will become famous soon enough
I would advise you to check physical quantities to determine if your solution is ok or nonsense. Do they change over the number of iterations after the residuals seem to be converged? If available compare to experimental data. For such simple cases it is often possible to do some analytical calculation and compare it to your results.
The mass residual can be missleading sometimes as it is scaled (divided by) the maximum residual of iteration 1 to 5. Fluent plots this scaled residual. If the maximum residual iteration 1 to 5 is already pretty low, the scaled residual will take large values. This would be typical for a interpolated case or a good initial guess.
It could also be possible that mass residual iteration 1 to 5 is already so low that the scaled residual takes large values as it is a very simple case. Further you could try to run the case in double precision.
"Check scale" means that the lenght unit in fluent and the lenght unit of your mesh has to be the same otherwise you have to scale your mesh. It is a pretty common mistake to forget scaling. You can run check mesh to display your domain extends in Fluent. As your case is very simple I don't think URFs should be the problem.
Also:
Originally Posted by bharath View Post
hi pibea,
Try first K-epsilon model (or other model) then switch to RSM (first order).
kad is offline   Reply With Quote
Old   January 10, 2014, 23:28
yea, as bharat said, check the scale of mesh..
General-- scale
check your dimensions, mm or m , cm ..for your geometry
Old   February 13, 2014, 17:42
shaham
shaham is on a distinguished road
I found a convergence problem in Fluent 15. I tried a simple 3D pipe model which I was using in fluent 14 and it had no problem in converging, however, in 15 the same case I use have the problem with the continuity.
I also tried the same 2D axisymetric case, and in version 15 it takes about 30% more iteration to converge the same conditions.
I wonder if anyone had this problem and if there is any solution for this problem?
Thanks
shaham is offline   Reply With Quote
Old   March 7, 2017, 06:17
raunak jung pandey
raunakjung is on a distinguished road
Were you able to solve the problems ? If Yes please comment
raunakjung is offline   Reply With Quote
Fluent Mixed Convection Problem cfdsolver1 FLUENT 7 September 19, 2016 04:58
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
