February 4, 2014, 08:24 |
Steady state VOF problem
I am solving a 3d almost cubic tank with a water inlet on one of the sides, a water outlet at the bottom. The head space of the tank is filled with air. The are a few baffle-like obstacles in the tank that I would like to look at the turbulent flow around them. I only need the steady state solution, and since the geometry is big and have many meshes because of odd scaling of the obstacles compared to the tank dimensions, I am assuming that unsteady state would take ages. So I chose st.st, implicit VOF all default settings. The first issue I have is the boundary conditions. I will only have my primary phase(water) in the inlet and outlet and most of the tank, and air only in the head space. Should I choose mixture in the boundary conditions? Apparently I am not able to choose different phases for different boundaries I have created. e.g. inlet, outlet, head space interior etc. Could someone please shed a light? |
outflow boundary in a steady state 1D convection diffusion eq. | hans-186 | Main CFD Forum | 2 | October 14, 2012 17:39 |
Convergence problem using simpleFoam steady state | vvqf | OpenFOAM Running, Solving & CFD | 12 | May 18, 2011 07:51 |
Steady state in VOF | CFD Newbie | FLUENT | 4 | December 18, 2002 16:11 |
Psedo-time steps in Steady state problem | Blackdraft | FLUENT | 0 | July 14, 2002 05:23 |
