turbulence kinetic energy at the near-wall node
Old   February 10, 2014, 10:05
Default turbulence kinetic energy at the near-wall node
itsme_kit is on a distinguished road
I applied standard K-epsilon model with standard wall function
I'm modelling air flow around 3d building
I only apply a single layer in the ground and building surface
Is it one thin layer enough? I only applied one because I didn't use low reynolds K-epsilon model
I set the inflation layer in 0.3m
Now I wanna find out the turbulence kinetic energy at the near-wall node
One thing I'm confused is that if the near-wall node is 0.3m above the ground
Thanks
itsme_kit is offline   Reply With Quote
Old   February 10, 2014, 15:57
kad
kad will become famous soon enoughkad will become famous soon enough
You should use more than just one layer. I never do less than 3 Layers, usually more.
In Fluent k-epsilon implies a zero gradient condition normal to the wall for k. Therefore the values of k on the walls are equal to the first node values, thus k is physically zero on the wall due to no-slip condition. In general you can view the first node values of all quantities by deselecting node values under contours.
kad is offline   Reply With Quote
Old   February 10, 2014, 16:09
Do you mean k in the first node is zero
How can it be
We need k for value of y plus
Old   February 10, 2014, 16:35
kad
Nope, it is a zero gradient condition. This does not mean that k is zero but that it does not change in the surface normal direction. Check out http://aerojet.engr.ucdavis.edu/flue...ug/node512.htm .
Old   February 10, 2014, 16:57
Hi Kad
Thanks for your reply
In the viscous sub-layer, u plus = y plus
I wonder why the error is significant if y plus is located in this region
Why we normally take y plus in the region between 30 and 300 (for example)
Is effect wall roughness excluded between 30 and 300
Old   February 10, 2014, 18:12
kad
Remember that k-epsilon model is only valid for fully turbulent flow. Therefore the first node has to be far enough from the wall where flow is fully turbulent. Then wall functions are needed to bridge the cell values with the wall values. If the first node is to close too the wall, you are using the turbulence model in a non valid region.
Wall roughness is generally not excluded but its influence depends strongly on the flow itself, e.g. it might be covered by the laminar sublayer.
Old   February 10, 2014, 18:25
Hi Kad
Thanks very much
I'm much more clear now, and still get some doubts to be clarified
If k is zero gradient and equal to the value of first node
Does it mean the velocity magnitude is non-zero at wall
If it is, how can we explain no-slip condition at wall
Does no-slip condition only confine tangential velocity is zero, not the normal component of velocity
In case we use low reynolads K-epsilon models, is laminar-sublayer solved too cause low value of y plus required for this model.
Does it mean the numerical results from low reynolads k-epsilon model is more accurate than standard k-epsilon model with wall function
Old   February 10, 2014, 21:15
kad
Originally Posted by itsme_kit View Post
Hi Kad
Thanks very much
Normal and tangential velocity is zero on walls. Like it is stated in the link above a modified k equation is solved in the near wall cells. Transport of k can still occur over the internal faces of a boundary cell so it isn't usually zero.
Yes
In general low Re models should give better results, but mesh requirements (especially wall resolution) are much more strict.
My general advice would be to remesh your geometry with a good resolution of the boundary layer and at least 5+ layers. Then use k-omega-sst as it overcomes some k-epsilon (and standard k-omega) weaknesses and can be used for y+< 30.
Modifying actuationDiskSource to inject turbulence kinetic energy pbachant OpenFOAM Programming & Development 0 December 3, 2013 11:43
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
turbulence kinetic energy? Eric FLUENT 1 December 3, 2000 10:41
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
