June 28, 2014, 16:35 |
Reynolds number input in fluent
Kim
Rep Power: 11 |
Dear all,
I would like to validate NACA0012 with experimental result which is available in NASA site. The input mentioned in NASA website is M=0.15 and Re=6 million. I can give M=0.15 in terms of velocity at inlet in FLUENT, but my doubt is "HOW CAN I GIVE RE=6 MILLION IN FLUENT". Thanks for understanding my silly question and please give me the solution. Thank you so much |
June 29, 2014, 06:20 |
Rick
Rep Power: 26 |
you cannot input directly the Reynolds number in fluent. As you know Re number is defined as: Re=rho*v*d/mu Re=Reynolds number rho=fluid density v=fluid velocity d=characteristic length mu=dynamic viscosity All in SI units d in your case, since you have external flow, can be the chord length. So you can calculate the velocity by fixing your Re number and other physical properties of the fluid and set a velocity input boundary condition in fluent. Daniele |
June 29, 2014, 09:24 |
#3 | |
Kim
Rep Power: 11 |
Hi Daniele,
Thank you so much for your reply!! But, i have still some doubt.. As you said, i can fix my "Re" and i can calculate "Velocity". But my objective is inlet Mach number should be 0.15, my Re should be 6 million for validation. When i calculate Velocity based on my required "Re", the velocity may be different from my Velocity calculated from my required Mach number. So, how can i my purpose will serve? Mr.Daniele, i am sorry for struggling you with my silly questions! Thanks kim. Quote:
June 29, 2014, 10:56 |
Rick
Rep Power: 26 |
you can calculate velocity based on Reynolds number or Mach number. If you want to fix Mach number simply calculate velocity as v=(Mach number)*(sound velocity). Daniele |
June 30, 2014, 05:51 |
Kim
Rep Power: 11 |
Dear Daniele,
Yes you said is right, we can calculate velocity based on Mach number also. Experimental data (for M=0.15 and Re=6 million) for NACA0012 airfoil is available in NASA website. I need to do simulation on naca0012 in FLUENT and validate with the above mentioned experimental data. So, i have to use M=0.15 and Re=6 million to validate my fluent results with experimental data. So, i can calculate velocity using M=0.15 and i give this velocity at inlet in fluent. But if we calculate the "Re" using my velocity (M=0.15), i will get different "Re" other than Re=6million. So, i cannot validate with experimental data. So, how can i validate now? That is why i asked how can i give Re=6million in fluent as input. Please let me clarify my doubt in this regard. Thank you Daniele. |
June 30, 2014, 06:43 |
#6 | |
Anonymous
Rep Power: 14 |
Calculate velocity from M and then decrease/increase mu, for example. Note that other dimensionless parameters from your equations should be changed correspondingly. |
June 30, 2014, 10:10 |
Rick
Rep Power: 26 |
LiteCFD is right; make a pseudo fluid with custom density and/or viscosity to have reynolds=6 million.
Can you share the article you are trying to validate? |
June 30, 2014, 10:57 |
Kim
Rep Power: 11 |
Hi Danieli,
Please look into the link below http://turbmodels.larc.nasa.gov/naca0012_val.html I would like to validate in the above link (naca0012 airfoil) Thank you |
#9 |
Kim
Rep Power: 11 |
LiteCFD, thank you very much for your clarification!!
July 15, 2016, 01:56 |
Reynold number
#10 |
Rep Power: 9 |
hello everyone
I have simple question how can I change Reynolds number in fluent |
July 15, 2016, 03:39 |
#11 |
Rick
Rep Power: 26 |
There are various definitions of Reynolds number, depending on your application.
For flow in pipe you have the Reynods (Re) definition: Re=rho*v*d/mu rho: fluid density v: fluid velocity d: pipe diameter mu: fluid viscosity So, accordingly, to change Re you need to change one or more of the above parameters.
Google is your friend and the same for the search button! |
July 16, 2016, 10:06 |
Reynold number
#12 |
Rep Power: 9 |
hello all dear
I have a simple question how can I change rey number in fluent for example, I want to insert my rey number 33000 |
July 16, 2016, 12:01 |
#13 |
Rick
Rep Power: 26 |
Message #11
July 18, 2016, 02:15 |
Reynold number
#14 |
Rep Power: 9 |
my dear friend, I want to simulate passing flow from the plate by fluent but the problem is I don't know which items depends on rey number
August 3, 2016, 15:35 |
#15 |
Thusitha
Rep Power: 9 |
I presume when you say "which items depend" means the quantities that describe the Reynolds number. As far as I remember, its the plate length, flow density, flow velocity, and flow viscosity.
May 27, 2017, 04:17 |
characteristic length used by fluent
#16 |
JOHOR
Rep Power: 9 |
hey,i have one question. I do project aerodynamic analysis on car, the problem is I couldn't tell, whether fluent use which type of characteristic length(length or width of my car) to calculate Reynolds number to compute the coefficient of drag .Anyone knows?Thanks in advance.
October 14, 2017, 05:03 |
#17 |
Jennifer Von
Rep Power: 8 |
I think Cd is related to your flow projected area A=width*height. in 2D flow around cylinders , A=width*1=diameter of cylinder *1
November 11, 2017, 06:03 |
#18 |
Omar Faruk
Can I fixed Re=1*10^6 where velocity is 10m/s and the fluid is air??? if yes then how i can do this?
April 24, 2018, 12:07 |
airfoil
#19 |
Msvs
Rep Power: 8 |
how can we give reynolds number for flow over airfoil
May 10, 2019, 10:53 |
What about complex geometry?
#20 | |
Hitesh
Rep Power: 12 |
Seems easy when the geometry is simple but what happens when it is not? I have a complex geometry with varying diameter and varying cross-sectional area even for the same dia (because of obstruction in the flow). What can be done in such a case? What I'm thinking is that we'll have to break down the geometry in different parts and have to calculate Reynold's number for each. Is that the right approach? |
fluent, input, reynolds number |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
Setting Reynolds number in Fluent for plunging airfoil | quarkz | FLUENT | 2 | November 19, 2019 23:40 |
Applications of Reynolds Number | Nadeem99 | Main CFD Forum | 0 | December 10, 2012 02:10 |
Reynolds Number in Fluent | danwebb | FLUENT | 3 | March 17, 2011 06:16 |
Reynolds Number and Heat transfer Coefficient | panos_metal | FLUENT | 0 | January 7, 2011 06:37 |
