February 19, 2014, 21:34 |
Wrong result Heat Transfer in a Cavity
Abhi
Rep Power: 12 |
I am trying to simulate one of the cases given in following paper by
Metzger Cavity Heat Transfer on a Transverse Grooved Wall in a Narrow Flow Channel. in Fluent Re= 15000. The geometry is a 2D section I am using Standard K-Omega Model I am trying to get the Nusselt number. I first specify Total temperature at Inlet i.e. 320K and T_Wall= 300. I got wrong results. Then I tried opposite way: T_Wall=320K and Total Temp_Inlet=300k. I got some results and tried to plot Nusselt. Attached are the Results. I defined the Nusselt number through Custom Defined function as Nu= (Surface Heat Transfer coeff * Cavity Depth)/ Thermal Conductivity. I used the Thermal conductivity of Fluid i.e. k=0.02 w/m-k. I am new to Heat transfer area so I am not sure what I am doing wrong. Cases converged there was no problem with the case setup. I checked the dimensions of the geometry that's right. Please help. Thanks |
February 20, 2014, 03:55 |
Alex
Rep Power: 49 |
Read the manual how Fluent computes heat transfer coefficients. It differs from the usual engineering definition of a heat transfer coefficient.
February 20, 2014, 17:28 |
Abhi
Rep Power: 12 |
I read the manual. But first of all I wanna know how the temperatures should be specified. Is the Wall Temperature higher or the Inlet Temperature. First of all I wanna make sure that my case setup is right.
February 21, 2014, 03:49 |
Alex
Rep Power: 49 |
It doesnt matter. Both cases should yield the same result when set up correctly, provided you dont account for any temperature dependent material properties.
February 21, 2014, 10:52 |
Abhi
Rep Power: 12 |
Sorry, did'nt look at the experimental data properly. It was given in the form of string distance. I was getting the right results all the way. But the position of the inlet does affect the Nu distribution and the exit conditions.
I also a question about the stability of the discretization schemes. Is it OK to use Third Order MUSCL scheme or Second Order Upwind. I read that second order upwind is stable and reduces numerical dissipation. Thanks for the help |
February 21, 2014, 11:31 |
Alex
Rep Power: 49 |
The general rule of thumb for the interpolation schemes for the convective terms is: with higher order schemes you trade in stability for accuracy.
To answer your question: The second order upwind scheme is more stable compared to a third order MUSCL scheme and reduces numerical diffusion compared to the first order upwind scheme. Always use the scheme with the highest order that gives stable results. |
cavity flow, fluent 2d, heat transfer, nusselt number |
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 07:45 |
radiation heat transfer | GeHa | FLUENT | 1 | September 5, 2012 14:56 |
convective heat transfer in tall cavity | meda | Main CFD Forum | 1 | April 27, 2012 09:06 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 08:46 |
need papers on heat transfer | George | Main CFD Forum | 0 | November 27, 2008 07:42 |
