March 19, 2014, 06:34 |
Left-handed faces occur when moving a mesh
Rep Power: 12 |
my case in simple but i cannot send pictures of it, so i have to describe what i'm working on; I´m working on a 3D moving furnace grate to burn biomass. I have only one step of that grate, translating discontinuously forward and backward only X axis, that compresses the mesh in front of it while enlarging the one behind. so it´s something similar to the piston of a 2 stroke engine (but the face is squared and not cylindrical) I´m working with FLUENT 15 on a DYNAMIC MESH moved by a UDF (DEF_CG_MOTION) with LAYERING feature (ratio based 0.4 / 0.4), since the cells are hexaedral. The quality of the mesh is good, despite few cells (> 0.01 %) with high skewness or low quality ratio. THE PROBLEM IS: during the PREVIEW of the mesh movement, after 2 movement of the step (30sec), appears the warning "left-handed faces detected". If i ignore it the simulation runs until 98 sec, then NEGATIVE VOLUME error appears and blocks everything. I tried with a lot of different brief timesteps but there isn´t influence, since the speed is very low and cells are quite big (1cm) I tried whit the "mesh repairing tools" but, despite sometime it works (and i´m also able to check the mesh) the negative volume is detected as well at 98sec. I DON`T have any problem in using the "DISPLAY MESH MOVEMENT" Someone has encountered a similar problem or can advice me on how proceed to discover new info about this error? I thank you all! |
April 17, 2014, 18:41 |
navid
Rep Power: 16 |
I have the same problem exactly! Have you solved it?
left-handed, reversed faces. |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
