April 3, 2014, 09:32 |
cunningham correction
Rep Power: 12 |
hey!
I have different particle diameters in my simulation and want to use the stokes cunningham draglaw but therefore you can only set one value, so for only one diameter. I made an UDF for different correction factors (because of different diameters) as the following: DEFINE_DPM_DRAG(particle_drag_force, Re, p) { double cu, kn, drag_force; real g1 = 1.231; real g2 = 0.4695; real g3 = 1.1783; real l = 68*pow(10,-9); kn = 2*l/P_DIAM(p); cu = 1+kn*(g1+g2*exp(-g3/kn)); drag_force = 18/cu+2.7*pow(Re,0.687)/cu; return (drag_force); } It would be helpful if one can inform me if I can model that in this way and I am not sure in which range of Reynoldsnumber the cunningham correction is allowed, thanks Last edited by martin986; April 4, 2014 at 13:15. |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
Timestep and Pressure Correction Relationship in SIMPLE | rks171 | Main CFD Forum | 23 | May 4, 2012 01:04 |
Cunningham correction factor | negar1 | Main CFD Forum | 2 | November 1, 2009 02:43 |
Cunningham Correction factor for Particle tracking | John O'Brien | CFX | 4 | December 12, 2008 05:03 |
Pressure correction problem | richard_larson | OpenFOAM Running, Solving & CFD | 8 | October 30, 2008 08:48 |
