Simulation 'Unavailable'
Old   April 4, 2014, 17:30
Unhappy Simulation 'Unavailable'
Michael McHardy
michaelmchardy is on a distinguished road
I am new to CFD (around 2 months experience) and have been working on a number of simulations and have managed to run the simulations fine and present results using a number of contour plots however when I re-open my simulations (after saving the project in both the set up and main fluent workbench) the 'graphics and animations' section shows the contour plot as 'unavailable.'
This menas that every time I want to view my results I have to re-run the simulation which is very time consuming.
Does anyone know how I can successfully save my simulations so that when I re-open them I can view the contour plots etc without having to re-run the calculation.
Any help would be greatly appreciated as I am working to a strict deadline.
Thanks,
Mike
michaelmchardy is offline   Reply With Quote
Old   January 16, 2015, 03:59
saeb
saaghi is on a distinguished road
Hi Michael
Have you found the solution to your problem? Same thing happens for me.
Thanks
saaghi is offline   Reply With Quote
Old   January 19, 2015, 08:17
Jan Schulz
cubejan is on a distinguished road
After some iterations (or with a converged solution) in Fluent within a workbench project, just export the .cas and .dat files (File-->Export-->Cas and Data).
You can open these files with Fluent (I start Fluent directly in windows, not within a project, but both ways should work) later and all your calculated data is still available. You can continue the solution or change parameters etc.
I don't really understand the saving/overwriting policy in workbench either, so I use this method and it works for me.
(to save some disc space add ".gz" behind ".cas" during the export)
cubejan is offline   Reply With Quote
cfd, fluent, saving, unavailable
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 03:36
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 14:29
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
