2D piston in steady closed pipe flow BC query! |
April 10, 2014, 10:25 |
Lisa Marfell
Rep Power: 12 |
I am trying to model a 2D creviced piston in a rapid compression machine. As the fluid stays within the cylinder, the flow is a closed system. My aim is to analyse the flow field around the piston, looking particularly at pressure/ temperature changes. Due to platform issues, I am unable to use dynamic meshing or user-defined functions to simulate the movement of a piston. Therefore I am limited to steady flow and a moving wall boundary condition. The wall is moving toward the end of the cylinder, thus "compressing" the fluid. I am struggling finding the correct boundary conditions and was wondering if anybody might be able to help. Originally I had a velocity inlet of 10m/s at the piston seal, simulating the seal pushing fluid out into the main chamber as the piston moves towards the cylinder end (moving wall boundary condition also set to 10m/s). The visulations of the flow field contain vortices and what I might expect to happen in real life. However I was recommended that this wasn't particularly realistic to the practical boundary conditions. I was advised that it would be more appropriate to not have an inlet, but to have a mass flow outlet at the seal of the piston (provided the seal leaks slightly), would a pressure-outlet be more suitable? If I have no inlet and a pressure outlet, should I be using target mass flow rate in the pressure outlet boundary condition? the flow field visulation I get from pressure pathlines shows a vortex in the main pipe and also in the crevices, but there is no pressure distribution in the main section. I am confused which boundary conditions would be most appropriate for my application. Any help would be extremely useful! Thanks, Lisa Last edited by lmarf88; April 10, 2014 at 13:08. |
boundary conditions, piston, rapid compression machine |
Laminar , steady state pipe flow | andesameer | OpenFOAM | 31 | March 3, 2015 02:42 |
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) | florian_krause | OpenFOAM | 22 | June 13, 2013 21:25 |
flow in perforated pipe distributor | pertupd | ANSYS | 0 | August 12, 2009 08:36 |
Reverse Flow at Rotating Pipe Outlet | vismech | STAR-CCM+ | 1 | August 11, 2009 10:38 |
About Turbulence Intensity (Pipe flow assimilated) | gRomK13 | Main CFD Forum | 1 | July 10, 2009 03:11 |
