Some issue with DPM
Old   April 16, 2014, 12:29
Default Some issue with DPM
John
suchy_t is on a distinguished road
Hi everyone,
I have some trouble with discrete phase model in fluent 15, namely no evaporated. All tracked ecaped I attached screen shot on it.
mash 3500000 volumes
Boundary conditions
mass flow inlet 0.3 kg/s 400K
pressure outlet 200000 Pa
total mass fuel 0.066 kg/s (jet-a)
6 injection - Only differing localization
DPM options
tracking parameters - max. number of steps 100000, length scale 0.001m
number of continouis phase interations per DPM iteration - 1
Spatial Discretization, first for all parametres
under-relaxation factors 0.1 for all parameters
First 3000 iterations is compute only cold flow and next turbulence, energy and PDF
I would be grateful for any help
I noticed a mistake in the first screenshot. Flow Rate it should be 0.00011 (0.0011 at present) , number of streams are correct - 10
0.00011x10 x 6(injection) gives the result the assumed 0.0066kg/s - correct me if I'm wrong
suchy_t is offline   Reply With Quote
Old   April 21, 2014, 10:35
shoeb khan
shk12345 is on a distinguished road
to the best of my knowledge
no of steams=10 will not give you 10x of the mass.
Instead of that go in the physical model tab, on the turbulence there and give a value of 10 there.
Try it .
regards
shk
shk12345 is offline   Reply With Quote
Old   April 21, 2014, 11:13
John
Tkanks for reply,
I do not fully understand which physical model you mean. Can you explain ?
regards,
Old   April 21, 2014, 11:17
shoeb khan
Originally Posted by suchy_t View Post
Tkanks for reply,
regards,
I dont have fluent installed on my system so i cannot explain much.
See in your first figure attached there. There is second tab called as physical models.
In that tab there is a turbulence model parameter there. Put that value to 10 and then try, It should work
reagds
shk
Old   April 21, 2014, 11:28
John
I see. there are no possibilities of entering the parameter specified by you
Old   April 21, 2014, 11:29
shoeb khan
Sorry buddy
go in turbulence dissipation and t ry
Old   April 21, 2014, 11:37
John
If you mean Discrete Random Walk Model I had already set 10.
The problem is located in a different place, I think.
Old   April 25, 2014, 06:37
Maaz Ul Mosaid
maazulmosaid is on a distinguished road
suchy_t
I am facing the same problem now,
Did you find any solution?
maazulmosaid is offline   Reply With Quote
Old   April 25, 2014, 07:19
John
unfortunately not,
I only managed to evaporate one of the six vaporizers, bye I do not know the cause of this problem. In this moment I compute over again with different physic model.
Could you write yours boundary condition? inlet outlet, kind of engine ?
regards,
Old   April 25, 2014, 10:45
i am modeling coal combustion...
i think this mass decreases because at that inlet conditions of air, it cannot properly burn the fuel.
increasing velocity or temperature may help
Old   May 3, 2014, 05:49
John
I still have the same problem, even if I can evaporate by changing diameter distribution to rosin-rammel the temperature in the model is not changing slightly in comparison with cold flow.
please any advice
regards,
Old   May 3, 2014, 07:49
go to
graphics and animations>> particle tracks... >> selection injection name >> summary>> track
and see the report...
i think you will find something
how to use DPM from DPM file unsteady? Cloud FLUENT 0 November 10, 2011 04:25
DPM modeling Mohsin FLUENT 0 March 31, 2010 22:11
DPM issue cinmar FLUENT 0 March 27, 2009 05:46
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 11:58
slow after mesh for enhanced wall treat DPM joshkemp FLUENT 0 May 1, 2007 17:20
