#21 |
mohamed mohsen
Rep Power: 13 ![]() |
the non reflecting boundary is an option in the pressure outlet boundary conditions .. it is used to eliminate pressure waves reflecting from the outlet boundary and treats it like the boundary is set at infinity ... rotor 37 mesh is the same as 67 im just using reasonable aspect ratio as im not refining too much at the walls .. try to solve laminar and tell me what u got
#22 |
RacMat
Just finished with the laminar simulation... reversed flow at the outlet and inlet and a lot of oscillations in the mass flow rate :'(
#23 |
mohamed mohsen
what boundary conditions do u use?
#24 |
RacMat
Pressure Inlet and pressure outlet (averaged specification)...
#25 |
AndreiCFD
Hi All
Has anyone got a fluent mesh for the rotor67 ? Thanks Andrei Cimpoeru |
#26 |
Umer Sohail
Rep Power: 9 ![]() |
Hello all
i need guidelines and help from you all. I have done Rotor 67 steady state simulation in CFX and found great results and even validated with NASA results. Now i want to do same simulation in Fluent. I imported Nasa Coordinates and mesh it in turbogrid. Now i am having reverse flows in fluent. Kindly guide me the boundary conditions in fluent, such as inlet and outlet gauge pressure etc. Please |
#27 |
Umer Sohail
Hello all
#28 | |
Umer Sohail
fan, mrf, rotor 67, transonic fan |
simulation of Double pipe heat exchangers in FLUENT | teguhtf | FLUENT | 1 | November 6, 2014 02:42 |
Question about starting the simulation automatically one after another by Fluent | Anna Tian | FLUENT | 1 | January 23, 2014 19:23 |
Simulation on fluent 14 | NAD | FLUENT | 0 | September 11, 2013 02:05 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Can Fluent start a simulation from a negative time | Ted Chu | FLUENT | 10 | November 26, 2008 21:06 |
