May 7, 2014, 16:49 |
Natural convection convergence problem
Bruno Machado
Rep Power: 13 |
I'm trying to solve a square cavity (1x1m) with natural convection heat transfer. Both top and bottom are insulated, left surface is T=330K and right surface at T=300K. The Boussinesq approximation is use for density. Thermophysical properties: rho=1.127 Cp=1007 mu=1.9114e-5 k=0.0271 Beta=0.006092 gravity= -9.81 I already tried to start the simulation with default solution methods and after a few iterations chance momentum and velocity values in order to achieve convergence of the result, but it doesn't worked. Any other helpful suggestion? Thanks in advanced |
May 20, 2014, 09:01 |
Joe
Rep Power: 14 |
Hello!
Please share your case file to be checked. Regrads |
May 21, 2014, 02:21 |
Flavio
Rep Power: 15 |
Hi Bruno,
I suggest setting up a transient simulation (best way for natural convection in closed domain). Otherwise you have to control under relaxation factors. Regards
Bionico |
May 21, 2014, 06:49 |
#4 | |
Simas
Rep Power: 14 |
Could you expand your thought about why you need to do transient calculation for convective internal flow? It is because of iterations graph going up? I am doing calculation also with natural convection in closed domain and would like to know more |
May 21, 2014, 08:06 |
Flavio
Rep Power: 15 |
Hi zombiaska,
according to ANSYS Guidelines (and my experience with air flow in rooms) it's difficult to reach convergence, for continuity equation specially: this is due to a problem of mass balance. ANSYS suggests 2 ways to solve this problem: 1) Set up a transient simulation: the domain starts with a certain mass (calculated from initial conditions, of course) and mantains this value during the entire simulation. 2) Boussinesq approximation: it helps the convergence by using a constant density in some equations. Furthermore I suggest using RNG-k-epsilon as turbulence model in case of heat transfer in rooms. Anyway it's very difficult to find an ideal model for this kind of case: it takes a lot of time and effort! Best Regards
Bionico |
May 21, 2014, 10:39 |
ahmady.a
Rep Power: 12 |
Hi Bruno
your problem my be is turbulent.check rayleigh number. |
May 21, 2014, 12:10 |
sofia
Rep Power: 16 |
Hi
For natural convection use body force weighted for the pressure and power law scheme for the momentum and the energy equations. |
May 21, 2014, 14:59 |
Josue Fraire
Rep Power: 13 |
try to set a initial velocity for the domain in the "Solution initialization", try this to be close to the average velocity you expect or less
May 30, 2014, 15:38 |
#9 | |
sudhir
Rep Power: 17 |
Hi bruno,
Reduce the relaxation factors of momentum to 0.5 and reduce energy to 0.95 and check your solution..if its not converged, go till 0.1 for momentum and 0.9 for energy.. sudhir Quote:
June 2, 2014, 14:25 |
Great advice for natural convection problems!
#10 |
T
January 31, 2018, 04:18 |
#11 | |
Yuehan
Rep Power: 13 |
Many people recommend PRESTO! for pressure for buoyancy driven flows. |
convergence, fluent 14.5, natural convection |
Natural Convection heat transfer problem | srinivasa | FLUENT | 21 | November 11, 2016 06:08 |
Natural Convection - Problem in achieving converged solution | howhs | FLUENT | 2 | August 28, 2013 10:51 |
Natural Convection Problem - Helium | marzoa | STAR-CCM+ | 0 | April 18, 2011 14:12 |
Natural convection problem (CFX 11.0) | Willy | CFX | 0 | May 13, 2008 21:19 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
