find the cell(s) related to maximum continuity residual |
June 11, 2014, 13:49 |
Joe
I am wondering if there is a way to find out the position of the cell(s) that has high continuity residual. In my calculation I got the order of 10e5 for the continuity residual. As far I know, the number we see in the continuity residual is the maximum value in all domain. So in my calculation maybe there are a few number of elements that cause such a high value for continuity. In this case I can refine my mesh in that particular area and got correct answer. Any idea ? Thank you in advance! Hooman |
July 24, 2016, 10:38 |
Fabio Malizia
Hi Enayath,
I have a similar problem. Did you find a way to find out the cells that cause bad residuals? I would really appreciate if you can help me. Fabio |
July 24, 2016, 10:47 |
Joe
Hello Fabio,
I really do not remember how I could fix it. However, I can say you need to refine the mesh close to the boundary layers or change the settings...like time step or use Simple or Piso...If you use Design modeler and Meshing, you can find the quality or skewness or the relevant information after making the mesh in Meshing. You can check the number and the position of the bad elements in Meshing...go to statics and choose element quality or skewness or orthogonality to find the bad elements...You can also send me your case if you would like...I can take a look. Good Luck, Hooman |
July 25, 2016, 05:06 |
Fabio Malizia
Hi Enayath,
thanks a lot for the help. I found a way to visualize which cells have bad residuals: If you type: solve/set/expert you get the following questions: Save cell residuals for post-processing? [no] Keep temporary solver memory from being freed? [no] Allow selection of all applicable discretization schemes? [no] For the first write YES for the others keep no. Run one iteration. now you can visualize the contours of the residuals. I just made some isoclips of the higher residuals. I think these are real residuals and not scaled ones, since I get also some negative one. Do you think is a correct method? Fabio |
July 25, 2016, 09:48 |
Joe
Fabio,
Unluckily, I have no idea how does it work! Hooman |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
