Urgent questions about fluent settings
Old   June 15, 2014, 14:17
Default Urgent questions about fluent settings
futureamour is on a distinguished road
I am simulating the free surface turbulent flow of a water jet exiting a pelton wheel and I have some questions, that I would be grateful if someone can clarify to me.
1)the SST model I am using needs to have a y+ value for the adjacent to the wall cell of ~1.But also in the manual it says that Enhanced Wall Treatment that is the default for SST is y+ independent,and that the number of cells resolving the boundary layer is much more important.What is the story there?
2)If I try to make the y+ ~1,is there a difference between designing a very fine mesh that achieves this value(through the y+ calculator) and making a rather coarse mesh (with y+ ~50) and then perform 5-6 y+ adaptions (setting min 1, max 5) to refine it by decreasing the y+ value?Is there any limit in the # of adaptions you can safely perform?
3)There is little information about turbulence damping.In the manual it says that it is highly recommended for vof simulation,yet in the tutorial simulation of vof in the manual they do not use it.When i used it, I got rather weird results.Any thoughts?
4)Is there any post processing contour where I can see if I have accurately solved the b layer and if I have sufficient # of cells to capture it?
Any thoughts-suggestions, highly appreciated!!
Sorry for the lengthy post
futureamour is offline   Reply With Quote
Old   June 16, 2014, 09:19
François Grégoire
macfly is on a distinguished road
If it's a free surface flow, a water jet in the air, why do you consider walls?
Mesh adaption is very costly because a hexahedron is cut into 8 hexahedrons, and chances are you need to refine only along 1 coordinate (perpendicular to flow direction). If you refine manually, you will cut 1 hexahedron into 2 hexahedrons, not 8.
macfly is offline   Reply With Quote
Old   June 16, 2014, 10:00
Thanx for the reply!
Regarding the first question,the water jet is leaving the nozzle,so I have to consider also the nozzle (outer wall) and the regulating spear (inner wall).Sorry for not being clear enough about it.
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
[ICEM] Missing face error from FLUENT even after repairing mesh + other questions unknown159 ANSYS Meshing & Geometry 0 July 5, 2013 20:18
Fluent Help ........ URGENT!!!!!!! HELP PLEASE... preshitupadhye Main CFD Forum 0 October 27, 2010 11:53
Fluent - batch file - avoiding questions fluentguy FLUENT 1 June 14, 2009 16:57
beginner's questions about fluent paralle processing Renold FLUENT 1 May 18, 2009 00:53
