Modeling non ideal gas
Old   June 16, 2014, 08:40
Default Modeling non ideal gas
Fraiman Leonid
Stormy is on a distinguished road
Good day everyone,
I am trying run a simple cross flow heat exchanger using N2 fluid.
The temperatures range is 90 - 300 [K].
I have two streams, H@10 MPa and L@0.1 MPa.
I using temperature depended properties, i got from NIST site.
My question is regarding energy equation being solved by fluent.
As I understands it Enthalpy is calculated using h=cp*T releation.
The L stream N2 acts much like ideal gas, when H stream not.
It means h from NIST tables and cp*T are not behaves the same, h closely linear with T, cp not at all.
Should i modify my cp data, to fit: h - h.ref = cp* (T - T.ref ) ?
Stormy is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
