June 30, 2014, 03:49 |
Porous wall
--Select for US or Canada only--
Hi
I wish to model a tube flow with porous walls. There is a fluid flowing inside the tube and a fluid flowing outside the tube. I want to model this fluid-fluid interaction that happens through the pores. How do i do it ? Hope someone can help me out. |
July 10, 2014, 16:41 |
Anonymous
Rep Power: 13 |
Did you try using the porous zone option in cell zone conditions?
July 11, 2014, 07:00 |
Thanks for your reply!
What boundary conditions should i give while meshing it in gambit ? porous jump doesnt seem to work as it shows an error while opening in fluent. I think i have not quite understood the jump boundary condition properly. And regarding your suggestion, my model consists only of porous walls. Will porous zone work for this too ? |
July 11, 2014, 09:26 |
Anonymous
Rep Power: 13 |
I am not too familiar with Gambit. Also, as far as I know there isn't a porous wall BC. You can create a different part (or body) while meshing it and define the porosity in the cell zone condition.
June 7, 2022, 02:58 |
#5 | |
Rep Power: 4 |
Hi, I wish, meanwhile you could solve the problem. I have to model a capillary-membrane, whose wall is permeable and the water enters from the right side. Here one has a laminar flow, which means Darcy's law is accepted. I am trying to find out c1, c2, could you please support me with some tipps? best wishes, Venesa |
porous walls |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
how to specify a wall as porous wall in CFX | nagarjuna reddy | CFX | 3 | June 3, 2010 08:03 |
reg porous wall | Prakash | FLUENT | 0 | November 4, 2005 02:50 |
