July 22, 2014, 22:39 |
how to build a zone?
Rep Power: 16 |
Hi, everyone
I have generated a 3D mesh, and I wanna to monitor flow paramters in a specified area. But this area is not any zone of the original mesh. So how can I generate a mesh zone (not a surface) for such a specified area just for monitoring flow? thanks in advance |
July 22, 2014, 23:19 |
Rep Power: 14 |
You can separate a part of the domain by marking the region of interest and then separating either its cells or faces.
First mark the region using Adapt/Region, select the type of geometry and specify the parameters. Select mark, do not select adapt. This will create a marked register. If a hexahedron was selected the name of the mark region will most likely be hexahedron-r0. Now go to: mesh/separate cells and separate the mark register from your domain. This will create a new cell zone. If your domain name is int_fluid, then the new cell zone will be something like int_fluid::001. You can now apply surface or volume integral monitors for each cell zone independently. |
July 23, 2014, 01:26 |
#3 | |
Rep Power: 16 |
hi, sescobar,
thanks for your reply, it works. yes, i seperated the domain to a new zone. but it also generated several new surfaces, as you said, such as int_fluid:001. Is there any rules for the suffix of the name? I wanna write a journal to execute several cases, so I have to make sure if the name changes randomly. Quote:
July 23, 2014, 11:49 |
Rep Power: 14 |
I am not aware of the logic behind the numbering sequence of the surfaces in fluent. I have noticed that it is a function of the way the mesh is created. I have never done what you are trying to do. There is the possibility of listing the surfaces in your domain (surface/list-surface). If you compare the list before and after the separation you can determine the created surfaces and their correspondent index. A subroutine outside fluent could be written to create the journal files.
Your problem is quite interesting. Good luck! |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
