Launch fluid flow (fluent)
Old   August 17, 2014, 14:40
Default Launch fluid flow (fluent)
Nourhan
Nourhan is on a distinguished road
Dear all,
I am a beginner user of ansys fluent
i can't launch it from workbench
as i can't find it either at component systems or analysis systems
how can i solve this problem ?
Thanks all
Nourhan is offline   Reply With Quote
Old   August 17, 2014, 15:38
pakk will become famous soon enough
It could be that the Ansys installation that you have does not include a licence for Fluent. It is the only option I see, but I don't have much experience with the workbench environment. I always start Fluent directly, for example through the windows start menu, is that something you can do?
pakk is offline   Reply With Quote
Old   August 17, 2014, 16:17
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
can you locate fluent from start menu > run command?
Far is offline   Reply With Quote
Old   August 18, 2014, 02:21
Nourhan
Thanks For Your Reply
i can launch it directly but i begin to use program from 2 days from tutorial
and feel confused while using fluent directly
so could i all the time depend on fluent without help of workbench and load mesh from gambit (for example) directly ?
Old   September 2, 2014, 17:48
Carlos P.
carnaval is on a distinguished road
with gambit you save the mesh into a file ".msh" then you can read it from Fluent.
carnaval is offline   Reply With Quote
Old   September 4, 2014, 09:18
Prasun Dutta
pd.iiest is on a distinguished road
It is the problem associated with serial key.. Are you facing this problem from the very first use? If yes, then you have to re-install your serial key.. otherwise go to the ANSYS licence manager(Server ANSLIC_ADMIN Utility), open it as administrator , then first STOP the ANSYS licence manager(probably 6th option) and after that START it.. restart your system.. try to open workbench..Hope it will work
pd.iiest is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
Ansys fluid flow fluent dheeraj jain FLUENT 1 June 8, 2013 00:17
Different flow patterns in CFX and Fluent avi@lpsc CFX 6 April 17, 2012 01:22
