August 19, 2014, 07:27 |
Plotting velocity profile
Lily
Rep Power: 11 |
Hi everyone,
I'm new to Ansys so excuse me for the noob question. First thing I've tried with Ansys is analysing a 2D flow in a channel. I want to find the Length of the channel for which the flow is fully developed. I've done some calculations and eventually ended up constructing a geometry which I think will allow a fully developed flow, considering my Reynolds number (it's a laminar-viscous flow). Now, I want to plot the velocity profile downstream, and see if my profile is indeed fully developed. What I've done is I went to the XY plot and created a line which has a downstream X coordinate, and a Y coordinate going from 0 all the way to the upper wall. I expect to get a parabolic profile, yet I keep getting the profile attached. It's obviously not plotting the change of velocity in respect to Y, rather, it's plotting the change of velocity in respect to X (you can see the graph starts at X=0.213 which is my designated X coordinate, not Y, and goes all the way to the Outlet and beyond). What am I doing wrong??? Thanks in advance |
August 19, 2014, 08:23 |
Rep Power: 24 |
Change the plot direction to 0 1 0 and also check the correct definition of your line visualy.
August 19, 2014, 08:37 |
Lily
Rep Power: 11 |
I did try to change the plot direction to 0 1 0, but it's still wrong...
How can I check the definition of my line visually? |
August 19, 2014, 08:43 |
Rep Power: 24 |
Display it via the display mesh function.
August 19, 2014, 08:55 |
Lily
Rep Power: 11 |
Right, yeah, my line is correct.
I think I understand what the problem is. When I change the plot direction to 0 1 0 is actually does give me the right velocity profile, only it's half of it. My channel height is 0.009 x 2, but when I put my Y coordinates as -0.009 to 0.009 it only plots from 0 to 0.009, and forgets about the rest. I tried creating two lines, one from 0 to 0.009 and one from -0.009 to 0, but I get an error message on the second line ("surface creation failed"). It's probably because I've done my analysis on half a channel (0 to 0.009) and then mirrored it through the center line. DOH! How can I mirror my half plot then? |
August 19, 2014, 09:45 |
Rep Power: 24 |
I do not know if this is doable in Fluent. You can do a little workaround by writing the plot data to a file (check option write to file) and mirror the data manually in an external software like calc, excel, ... and then load it in Fluent.
Another option: Monitor an other flow variable. For a fully developed flow the derivative of velocity in flow direction should be zero. Plot the derivative in flow direction and check where it becomes zero. |
August 19, 2014, 10:04 |
Lily
Rep Power: 11 |
I've used excel and it works perfectly.
Thanks kad, you've been very helpful! |
August 19, 2014, 11:00 |
Alex
Rep Power: 47 |
From your first screenshot I can see that you are using the axisymmetric option.
This requires (or at least implies) that your entire model lies above the x-axis. The x-axis is assumed to be the axis of symmetry in fluent by default. So there might be something wrong with your setup if the extent of your computational domain ranges from -0.009m to 0.009m in y-direction. |
August 19, 2014, 11:29 |
#9 |
Lily
Rep Power: 11 |
The domain is fine. I've build my channel from 0 to 0.009 above the x axis, and after getting results I used Display>Views>Mirror Planes>Centerline to mirror the graphic results. It's just the XY plot that didn't work.
[UDF] Relative coordinates in logarithmic velocity profile | cfdworker | Fluent UDF and Scheme Programming | 25 | July 13, 2017 03:44 |
Velocity profile boundary condition | Tuca | FLOW-3D | 1 | April 23, 2013 12:02 |
Logarithmic velocity profile | cfdworker | Fluent UDF and Scheme Programming | 0 | April 23, 2009 19:09 |
[boundary condition] logarithmic velocity profile | cfdworker | FLUENT | 2 | April 17, 2009 23:36 |
Prescribed inflow velocity profile - how to? | Alan | Main CFD Forum | 10 | October 28, 2005 12:14 |
