Shape Factor
Old   August 20, 2014, 04:44
Default Shape Factor
venkatesh
venkat_aero2007 is on a distinguished road
I am analyzing transition point over NACA 4412 airfoil at low Reynolds number using Transition Kw-SST model. I am using FLUENT for simulation. I dont know how to plot Shape factor from FLUENT result. I know that Shape factor can be calculated using the relation
where H is the shape factor, is the displacement thickness and θ is the momentum thickness.The definition of displacement thickness, δ for incompressible flow is
Where and are the density and velocity in the 'free stream' outside the boundary layer, and is the coordinate normal to the wall.
The definition of Momentum thickness for incompressible flow is
I read in a post that velocity profile can be obtained by creating a line perpendicular to the surface at the point of interest. and with the help of that line velocity variation can be plotted.
I don't know how to plot shape factor in fluent. Can anybody please help me in this regard.
venkat_aero2007 is offline   Reply With Quote
Old   August 20, 2014, 12:19
livy is on a distinguished road
You should get the parameters such as velocity and density along the line and then you can calculate the shape factor.
livy is offline   Reply With Quote
Old   August 20, 2014, 14:03
venkatesh
i am able to obtain velocity, density along the line but i dont know what to do next and how to manipulate these values to obtain displacement thickness, Momentum thickness and Shape factor
Old   August 20, 2014, 22:12
You obtain these tow parameters and with the distance to the wall,you can calculate the value of the thickness displacement and momentum displacement by the equations you list above using a program or matlab. Then you work is done.
conduction shape factor shahrbanoo FLUENT 1 May 23, 2013 07:22
Shape Factor NickSD Main CFD Forum 0 July 26, 2010 10:39
shape factor ANDRES FLUENT 2 November 4, 2008 16:36
How to calculate shape factor of spherical cap bub Rajeev Kumar Singh FLUENT 0 October 6, 2005 13:07
Shape factor for spherical cap bubbles Rajeev Kumar Singh FLUENT 0 October 1, 2005 13:51
