define a time dependent inlet velocity
Old   August 21, 2014, 21:52
Default define a time dependent inlet velocity
ansys_matt is on a distinguished road
Since nobody can figure out how to make fluent initialize the Cell Zone Conditions properly to contain a mixture, I will use this workaround.
I figure I can have the inlet run long enough to fill the interior with the mixture since fluent cannot start the simulation with the interior full of the mixture as an initial condition. But to do this I need to have the inlet velocity run for, say, 5 seconds to fill the tank, then shut off for the rest of the simulation.
So is there a simple way to have fluent run at v0 for only 5 seconds then set the inlet velocity to 0?
Thanks
ansys_matt is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Reusing the inlet time directories in timeVaryingMappedFixedValue ngj_22 OpenFOAM Running, Solving & CFD 0 January 24, 2013 10:22
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
