pressure distribution and drag for a surface piercing cylinder in OCF
Old   September 15, 2014, 17:47
Thumbs up pressure distribution and drag for a surface piercing cylinder in OCF
kevin
kevinmccartin is on a distinguished road
Hi, Ive been assigned this as part of a final year mechanical engineering project. New to CFD but has anyone done a project like this before? learning FLUENT at the moment(turbulent jet lab)...
The aim of this project is to measure the static pressure on a cylinder surface(geometry depth and flow rate) and model the problem using CFD software for comparison.
The results desired are to figure out the overall drag and calculate from the pressure data the % of overall drag due to pressure.
Anyone who has done something similar before any starting points/words of advice/stumbling blocks would be massively appreciated.
Kindest Regards
Kevin
ITT Tallaght, Dublin
Dept of Mech Eng
kevinmccartin is offline   Reply With Quote
Old   May 19, 2016, 12:46
Shanmukh Damarla
shannu.damarla is on a distinguished road
hi kevin,
i am shanmukh, final year btech student ... my project is something simillar to yours ... to find out drag of a surface piercing object using fluent..... can you help me out in how you put the set up in order to run the calculation and obtain the result?
regards,
Shanmukh
shannu.damarla is offline   Reply With Quote
cylinder, drag, fluent, piercing, surface
drag and lift calculation of a cylinder in wind tunnel fewgoodmen Main CFD Forum 4 February 24, 2014 15:05
Pressure drag calculation lc05 Main CFD Forum 2 November 1, 2010 07:50
anyone has got this paper? Al Main CFD Forum 3 October 8, 2007 02:04
Drag and Lift in 3D flow around a cylinder... Renato N. Elias Main CFD Forum 16 October 4, 2005 11:32
Pressure distribution over an airfoil-help Andrew Parker FLUENT 4 February 13, 2002 11:51
