Simulating a room
Old   August 17, 2014, 05:29
Default Simulating a room
Michelle
miquiita is on a distinguished road
I am trying to simulate a room in Fluent with a ceiling fan, but I am not sure how to start or if it is possible to do this?
Michelle
miquiita is offline   Reply With Quote
Old   August 20, 2014, 04:32
ringtail is on a distinguished road
Originally Posted by miquiita View Post
Michelle
Before you build the simulation model, you have to determine the object of your simulation. Models varies for different objects.
ringtail is offline   Reply With Quote
Old   September 1, 2014, 03:07
Default Ceiling fan in a room
Michelle
Hi all I am trying to simulate a ceiling fan in a square room. I am first wondering the best approach for creating a room model and then how to use a rotating fan in a simulation.
Old   September 3, 2014, 17:26
Ahmad Al-Zoubi
aalzoubi06 is on a distinguished road
What do you mean by "creating a room model"?.
From your question, it seems that you are a CFD beginer. So my suggestion to you is to try to do some tutorials, using the CFD tool which you have in your institute. Then try to find a tutorial which is similar to your case. If not available, read the user guide manual to find the way how to setup the rotating part and to go ahead.
Wishing you all the best and success
Ahmad Al-Zoubi
https://sites.google.com/site/ahmad6alzoubi/
aalzoubi06 is offline   Reply With Quote
Old   October 11, 2014, 07:27
Abhya is on a distinguished road
Its possible.
Work out some tutorials under Rotating reference frames in FLUENT.The boundary conditions for this problem are a bit tricky though I guess
you need to use rotating reference frame to model the fan motion in fluent and in every CFD software available.I have never seen any CFD package which doesn't have the Rotating reference frames
Abhya is offline   Reply With Quote
[blockMesh] Simulating a room superian OpenFOAM Meshing & Mesh Conversion 3 April 1, 2015 10:21
[ICEM] Ogride in of a room in ICEM CFD metmet ANSYS Meshing & Geometry 3 July 31, 2014 14:00
[GAMBIT] Object in room with that object being the purpose of investigation fluentgambituser ANSYS Meshing & Geometry 3 August 24, 2011 01:52
Anyone has step by step guide from geometry to simulating air flow in room binghong ANSYS 0 September 30, 2010 23:50
Salome and Code Saturne simulation of simple room and objects cristian.ocnarescu Main CFD Forum 0 June 21, 2010 10:19
