Setting Initial Temperature Of a Domain
Old   October 17, 2014, 06:22
Default Setting Initial Temperature Of a Domain
Michael
mjkey is on a distinguished road
Hey Guys,
I'm trying to model the temperature in a car.
Basically the geometry i have is the inside fluid domain of the car. Or you can just treat it as a room.
I'm thinking of using the convection wall boundary condition. Setting a heat transfer coefficient and free stream temperature to 323.15K. Now I have air entering into the car at 300.15K. I want to know how to set an initial temperature in the domain, say 313.15K. Can someone please tell me how to do this?
To clarify, once the simulation begins, I want to fluid domain inside the car to be 313.15K and as the air flow into the car, I'm want the domain to gradually decrease(or whatever will happen) with mixing.
Thanks Guys!
mjkey is offline   Reply With Quote
Old   October 17, 2014, 08:53
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Originally Posted by mjkey View Post
Hey Guys,
Thanks Guys!
It's an easy thing. Only initialize your solution in "solution initialization" submenu in solution menu or use patch option near to it. In patch, you can impose initial values for your variables (depends on which governing equations you use in your model), say, temperature in the whole domain or any zone you like.
Regard yours
A CFD free user is offline   Reply With Quote
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 18:17
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
