October 22, 2014, 06:48 |
Visualize high residual Cell in Fluent
Daniel
Rep Power: 21 |
Hello guys
I am modeling a pulsatile flow through an artery with Ansys Fluent. However I have a problem in convergence after a few time step. The same case converges well when I use Newtonian fluid model for the blood, but switching to any non-Newtonian model causes a convergence problem after a few time step. I am using pressure-based coupled solver with the default settings. I have already tried reducing courant number and under relaxation factors with no luck. I have also tried different P-V coupling schemes, but the exact same behavior occurs after a couple of time steps. Is there any way to visualize which cells are causing the problem? So I can try and fix the mesh. The current mesh quality metrics are as follow: - maximum skewness : 0.6 - maximum aspect ratio : 36 - minimum orthogonal quality: 0.5 Thanks in advance |
October 25, 2014, 15:04 |
Daniel
Rep Power: 21 |
anyone?
July 24, 2016, 10:23 |
Fabio Malizia
Rep Power: 16 |
I was also looking to a way to visualize the cells which are causing bad residuals. Did you find any method ? Thanks, Fabio |
log file | imani | OpenFOAM Running, Solving & CFD | 0 | July 24, 2014 02:04 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
pisoFoam - unstable pressure residual | Industrial_CFD | OpenFOAM Running, Solving & CFD | 21 | February 24, 2013 15:39 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
