Discontinuity between rotating and stationary walls |
October 28, 2014, 07:28 |
Musa
Rep Power: 17 |
Dear all,
I`m trying to simulate the flow in an enclosed rotor-stator system. The attached figure represents the quarter of my geometry. The axis of rotation is y-axis. Faces are the rotor (red), the stator (blue) and the shroud (yellow) in the figure. The shroud is attached to stator and hasn`t got any motion/rotation. My question is that I couldn`t find any info from Fluent User`s Manual about the discontinuity between the rotor and the shroud. Does anyone know how does Fluent resolve this discontinuity problem on the line between these stationary and rotating walls? Regards, Musa |
October 28, 2014, 12:10 |
#2 | |
Amin
Rep Power: 14 |
Is rotor rotary and shroud stationary? Is them have a contact? Contact between rotary part and stationary part? |
October 28, 2014, 12:26 |
Musa
Rep Power: 17 |
Hi Amin,
Thanks for your response. Yes the rotor is a rotating wall and the shroud is stationary wall. I have just modeled a 3D cylinder and defined its faces as my rotor, shroud etc. So yes there is a contact between rotating and stationary walls. And there is a discontinuity on that contact which is the line between these faces in my case. |
October 28, 2014, 13:03 |
Rick
Rep Power: 26 |
This can't be a real machine: why do you want to simulate a non real object?
Google is your friend and the same for the search button! |
October 28, 2014, 15:53 |
Musa
Rep Power: 17 |
Thanks for your reply Daniele,
Yes, you are right. In reality there should be a thin gap between rotor and shroud, say, the gap is 0.01*r (r is the radius of the rotor). I found in some papers, for example Severac & Serre (2007), that this kind of thin gap hasn`t got a significant effect on the flow and they used the geometry I attached in their own simulations. They said the discontinuity is regularized by employing a BL function into their code. So I just wonder if Fluent has any specific capability to resolve that kind of issues. Or should I consider to implement a UDF to that boundary somehow? |
October 29, 2014, 01:56 |
Amin
Rep Power: 14 |
Do you have any heat transfer in solid domain?
because for solid domains only energy equations is solving, if you don't want to calculate temperature distribution, I think you can assume the part of the shroud that have a contact with rotor, as rotary part! And why would you want to model a contact between them? Why you don't model a gap between the parts? |
October 29, 2014, 04:08 |
Musa
Rep Power: 17 |
Thank you Amin,
There is no heat transfer. I tried to run it and it seems working without any error notification. But I guess I need to carefully consider the results since I don`t know what is happening there. Regarding your suggestion, if I model a thin gap between these parts, would it be just defined as an opening or what? There would be no inlets/outlets apart from that thin gap, so would it create a convergence problem in continuity equation? Many tanks with regards, Musa |
October 29, 2014, 14:57 |
#8 | |
Amin
Rep Power: 14 |
October 29, 2014, 18:26 |
#9 |
Musa
Rep Power: 17 |
I do not understand your suggestion, I'm afraid. If I define the gap as a wall, why should I remodel my domain? Do you mean that I should separate my rotary part and shroud with another little stationary wall? If so there is still singularity between my rotary part and the thin gap (defined as a stationary wall), isn't it?
October 29, 2014, 22:58 |
#10 | |
Amin
Rep Power: 14 |
October 30, 2014, 04:51 |
#11 |
Musa
Rep Power: 17 |
Thank you very much Amin. If there is any further approach to this topic, it will be appreciated. Thank you all for your kind responses.
Regards |
Rotating and stationary walls | martijnal | CFX | 3 | October 16, 2016 06:05 |
Rotating Domain + Stationary Domain + Interface Acusolve | bench | Main CFD Forum | 3 | July 7, 2015 11:34 |
Simulating flow for rotating cylinders with a stationary body in the annulus | diwakaranant | SU2 | 5 | December 10, 2013 05:09 |
Viewing Rotating and Stationary Domains in Post | tango711 | CFX | 1 | August 23, 2012 08:09 |
rotating propeller in stationary baffled vessel | wlt_1985 | FLUENT | 27 | March 30, 2011 01:22 |
