Transition SST 4 eqn in FLUENT
Old   November 13, 2014, 05:25
Default Transition SST 4 eqn in FLUENT
Naimah
wanna88 is on a distinguished road
Hi
May I know,
a) In what conditions do we need to set for "Roughness Correlation" and "Curvature Correction" for Transition SST 4 equations in FLUENT?
b) How to calculate/specify for " Geometry Roughness Height"?
Thank you
Naimah
wanna88 is offline   Reply With Quote
Old   November 13, 2014, 05:37
ghost82's Avatar
Rick
ghost82 will become famous soon enough
What's the meaning of writing 5 times the same question????
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   November 13, 2014, 06:22
pakk will become famous soon enough
If I see a question asked once, I give an answer if I can. But if I see the same question asked five times, without links to the other question, I don't bother.
I would advice Naimah to avoid doing this in the future. It is bad etiquette. You might consider removing 4 of the five posts, or replacing them with links to one thread.
pakk is offline   Reply With Quote
Transition SST tuning using UDFs robboflea Fluent UDF and Scheme Programming 2 May 16, 2013 12:31
Transition SST model for vertical axis turbine baggiovive FLUENT 0 August 17, 2010 13:32
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
to LANGTRY ROBIN :help, hypersonic transition SST ben akih CFX 0 September 21, 2006 04:59
flat plate transition: SST k-omega divergence Peter Gasparovic FLUENT 4 May 3, 2005 13:54
