Fluent shuts down without warning
Old   November 25, 2014, 13:12
Exclamation Fluent shuts down without warning
herrolsen is on a distinguished road
Hey everyone!
I have a problem, fluent is shutting down without a single warning.
I'm running an implicit VOF, implicit body forces, gravity and open channel flow. Everything converges nicely in around 20 iterations.
I'm working on a remote computer, everything looks fine until the window suddenly freezes and I get kicked out of the connection. Me getting kicked out could mean it looses its connection to the net, but no way a 10 sec of lost connection will cause fluent to shut down!
I get no error messages in workbench whatsoever.
Has anyone else had this problem?
herrolsen is offline   Reply With Quote
Old   November 25, 2014, 13:47
Managed to do a screenrecord to read the error message.
It says:
Node 2: Process 227548: Recieved signal SIGSEGV.
MPI Application rank 0 exited before MPI_Finalize() with status 2
I read somewhere that people ended up needing to update their version of Fluent to make it work again. I am on 15.0.0 so thats not an option.
Do I have any other options or do I have to restart in serial?
Old   November 25, 2014, 19:55
lisa_china is on a distinguished road
you use parallel computation? maybe you can try to change MPI to another transmission protocol.
lisa_china is offline   Reply With Quote
Old   November 25, 2014, 20:48
Thanks for answering! Can you point me in the right direction to do so?
Edit: Yes! Running i parallell
Old   November 26, 2014, 02:55
there is a "parallel setting" button when you start fluent(i use fluent 14.5) and usually i use pcmpi.
and herrolsen, i'm not sure whether it will work.
Old   November 26, 2014, 03:15
B_Kia
HyperNova is on a distinguished road
maybe the software need to access to some data in domain that you have not sepecified
HyperNova is offline   Reply With Quote
Old   November 26, 2014, 13:15
Allright, so it means scrapping the data I have and starting over again either way :/
Which MPI type should I pick, intel?
Old   November 26, 2014, 13:16
Im not sure I understand. Could it be a result of a bad mesh?
Old   November 26, 2014, 15:33
Lucky
I also think it's an mpi problem. To verify, try running in serial mode and see if the problem still occurs.
Old   November 26, 2014, 15:48
B_Kia
for example in a udf the code needs to access to tempreture but the energy equasion is not turned on
Old   November 26, 2014, 18:45
definitely! I've tried on two different computers and both shuts down at the exact same time. The fact that they both shuts down at the same time is what led me to believe that it could be a mesh problem. The time is around where the water starts reaching the bottom! Could it be possible that I have a problem in my mesh and this causes the problem?
HyperNova - I do not use any UDF and even left surface tension off, so I think we can rule that out. Thanks for explaining!
Old   November 26, 2014, 20:27
So far I've tried the different MPIs on available on the computer and only pcmpi (default) works, choosing another one causes fluent to crash. So for now, as suggested, it is running in serial!
Old   November 26, 2014, 21:06
did fluent also shut down when you using pcmpi?
Old   November 26, 2014, 21:08
from what I can tell pcmpi is the default one, so this is the one that crashes at the specific time. The other MPIs wont start at all!
Old   November 28, 2014, 03:43
ok, sorry to mislead you
Old   November 28, 2014, 12:00
No misleading, my explanation was probably a little fuzzy to begin with I appreciate all help!
crash, shutdown
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 00:52
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
OpenFOAM Solaris mamaly60 OpenFOAM Installation 13 May 10, 2010 21:16
