adding fuel data to thermo.db
Old   December 2, 2014, 11:44
Default adding fuel data to thermo.db
mathew
mathewvargheset is on a distinguished road
i am doing non premixed combustion modelling. i want to add c10h16 as my fuel. when i am adding this in the boundary condition an error occurs
"Please add species c10h16 to your thermo.db file"
how can i do this
mathewvargheset is offline   Reply With Quote
Old   February 27, 2015, 08:26
Bedfordshire
Aryadutt is on a distinguished road
Have you found a solution for this? Even I am having the same issue, I need to add C3H8O as fuel.
Aryadutt is offline   Reply With Quote
Old   February 27, 2015, 09:49
mathew
no yaar..only way in fluent is that find another fuel which is there in the thermo.db file which has almost the same properties of the fuel u need
Old   February 27, 2015, 10:07
Bedfordshire
ohh ok....another problem which I am facing now is, when i give a particular velocity in the velocity inlet condition, I am getting a very different mass flow rate through the inlet. I used Report-> Fluxes option to see the mass flow rate. Do you know how the mass flow rate is calculated in fluent from the velocity inlet condition?
Old   March 1, 2015, 12:54
kai
zkzkzk010537 is on a distinguished road
From my experience, you just need to find those polynomial constants which represent the properties of certain species and add them in your thermo file.
And yes, it is difficult, those depend on some kinds of standard, probably NASA. And we can find some const. provided by them.
zkzkzk010537 is offline   Reply With Quote
Old   March 1, 2015, 12:56
kai
mass flow rate = velocity*area*density, maybe you have assigned your velocity to a different inlet.
Old   March 25, 2021, 10:09
Ankara
josepholathe is on a distinguished road
for example i need create a material which called as eugenol i should find another fuel which has almost the same properties.
in that case what about chemical formula or content of carbon or hydrogen in the chemical composition.
Does difference between the two type of fuels chemical formula effect the calculation of the pdf table or anything else?
josepholathe is offline   Reply With Quote
Error when reading data file. WJXu FLUENT 7 September 1, 2015 19:34
[General] Warping Cells by Vectors? ronwelty ParaView 10 April 29, 2014 05:52
how to pickup the mesh data and vector data oga_shin OpenFOAM 2 October 27, 2011 23:42
Data collecting for Fuel mass fraction. Yee-Hern.Tan FLUENT 1 March 4, 2009 22:23
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
