Boundary condition of the fluid type for tube-in-tube heat exchanger
Old   January 7, 2015, 09:12
Default Boundary condition of the fluid type for tube-in-tube heat exchanger
Ashraf Mimi is on a distinguished road
Dear all....
Please i have an important question.... currently i am working on improving the effectiveness of tube-in-tube heat exchanger numerically using FLUENT 6.3.The boundary condition of the fluid in inner tube is Turbulent and for outer tube (Annulus) is Laminar? what is the suitable model of the program can handle and give satisfactory results for this case to validate with experimental work....
My respect....
Dr. Ashraf Mimi
Ashraf Mimi is offline   Reply With Quote
Old   January 8, 2015, 23:46
sache is on a distinguished road
U can use K-e Realizable model....
it will give satisfactory result
sache is offline   Reply With Quote
Old   January 9, 2015, 07:16
Thumbs up Thank you Sache for reply and answer
Thank you and my especially respect for your answer Sache and reply ....
K.e model Realizable as you said is suitable for case above... do you have a reference for your answer???
Which wall near treatment of of the following suitable too?
-Standard wall functions.
-Non-equilibrium wall functions.
-Enhanced wall treatment.
-User-defined wall functions.
I have another question....
Some one of my supervisors told me you should select your limitation of flow for two pipes corresponding to laminar flow Re<2300 or two pipes Turbulent flow Re>4000
What about your opinion for the idea above to overcome the difference in the type of fluid in two tubes if we are not have reference for your answer above???...
Thanks .....
Old   January 9, 2015, 07:17
Dear all ....
Please i need answer for my Questions above???
Thanks
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
singularity? mihaipruna OpenFOAM Running, Solving & CFD 5 April 24, 2012 17:18
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
