January 12, 2015, 04:54 |
Cell Zone Frame Motion
Rep Power: 11 |
Hi all,
I have to simulate the heating of a moving body (a polymer sheet) into a hoven. I wonder to use the "Frame Motion" option applied to the polymer sheet body, chosing the good translational velocity. After that i will set moving walls between the polymer and the air. It is sufficient or I need to set a mesh motion? How it is possible to check if the body (the interior) is really moving? I have the impression that only the walls are moving.... Thanks in advance philus |
January 12, 2015, 05:58 |
Antonio Casas
Rep Power: 13 |
If you set a mesh motion, then you can use mesh motion preview and see what is and what is not moving.
Please could you take a look to my thread and see if you can help me too? http://www.cfd-online.com/Forums/ans...eed-valve.html http://www.cfd-online.com/Forums/flu...g-useless.html Thank´s a lot, and good luck |
January 12, 2015, 06:12 |
Rep Power: 11 |
I can't try it because my simulation is stationnary...
...also it makes sense to set a mesh motion for a steady-state simulation? |
fluent, frame motion |
Error in solution using "Grid Interface" | agustinvo | FLUENT | 4 | January 20, 2015 12:03 |
stop lagrangian parcels in cell zone | Chrisi1984 | OpenFOAM Programming & Development | 3 | August 20, 2014 14:35 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[GAMBIT] Problem with interior faces | miro2000 | ANSYS Meshing & Geometry | 11 | August 24, 2013 14:00 |
how to treat the rotating zone in multiple reference frame (MRF) | Jiuan | FLUENT | 4 | May 24, 2010 21:58 |
