Using UDF in fuel cell addon module
Old   January 27, 2015, 20:57
Question Using UDF in fuel cell addon module
Brian
qwe2077 is on a distinguished road
Hi I'm using PEM fuel cell addon module in fluent.
I'm tring to model the micro porous layer to a unit cell.
But in the fuel cell module, I can give only one porocity and one contact angle to the porous cell zone.
So I need to change boundary conditions in the porous media.
then I should use UDF macro to give boundary conditions.
so I got in to the pem_user.c file and found
DEFINE_DIFFUSIVITY(diff,c,t,j_spe)
return pem_diff(c,t,j_spe);
and in the pem.h file,
real pem_diff(cell_t c, Thread *t, int j_spe);
My questions are,
1. Is there no way to see the contents of pem_diff(c,t,j_spe) ?
2. How can I use UDF Macro in the fuel cell addon module?
3. Can you give me a advise about modeling extra layer of porous media?
qwe2077 is offline   Reply With Quote
Old   February 11, 2015, 14:17
Default fuel cell module addon_code
walied
walied123 is on a distinguished road
hi, dear
to see the content of the addon code of fuel cell please follow the directories "C:\Program Files\ANSYS Inc\v145\fluent\fluent14.5.0\addons"
you can make change to the pem code and do the recompilation again.
see the attached pdf file for more datails.
walied123 is offline   Reply With Quote
Old   February 11, 2015, 22:33
Brian
Hi walied123 thanks for your reply.
yes I know Ansys provides user-accessable-functions in pem_user.c file in addons/src folder as you mentioned.
I want to see and change the contents of UDF of source terms and charge transfer conservation.
In the C-file, I couldn't find any content of them.
please help me
Old   February 12, 2015, 02:55
maverick123 is on a distinguished road
If you want to see the equations how these source terms are calculated by default..check the fuel cell manual..it is given over there...
please help me
maverick123 is offline   Reply With Quote
Old   February 12, 2015, 03:18
Brian
Thanks again maverick.
I've checked out the fuel cell manual. It was a lot of help.
How can I see the c-code of default source terms and UDS flux, UDS diffusion?
Are they not opened to see?
There are only declare exression in C file and I can't find the C-code contents of those UDS function.
Old   February 12, 2015, 03:25
I think, you can not see it as it is not available for Users. But you can modify it for sure with your code/equations.
fuel cell, module, udf
Setting cell variable values in a fluid zone using UDF eromon84 Fluent UDF and Scheme Programming 6 March 28, 2021 11:59
Identifying cell in parallel UDF upeksa Fluent UDF and Scheme Programming 0 July 24, 2013 11:27
UDF for heat source on surface instead of the whole cell zone?? benson621 Fluent UDF and Scheme Programming 4 December 8, 2011 11:54
Fuel Cell Module Tutorial Mesh File. PEM_Fuel_Cell Main CFD Forum 1 September 13, 2006 16:11
Warning 097- AB Siemens 6 November 15, 2004 04:41
