Divergence probleme
Old   January 28, 2015, 03:09
Post Divergence probleme
adam
dahmen is on a distinguished road
Hi everybody;
I have a problem that i can't resolve. PLEASE any help is appreciated.
The calculation was stopped and showed me a message "Divergence detected in AMG solver: x-momentum", and in the console the error message was screened and suggested to increase the relaxation sweeps "Divergence detected in AMG solver: x-momentum -> Increasing relaxation sweeps!". What that means, and how to do it?
dahmen is offline   Reply With Quote
Old   January 30, 2015, 09:33
Cees Haringa
CeesH is on a distinguished road
It means that, for whatever reason, your solution doesn't converge (and in this case the x-momentum equation is the problem).
There are a few things you can try; like decreasing your under-relaxation factors, decreasing your timestep size (in transient), decreasing your mesh size (increases accuracy, but also computation time), or possibly change your model equations.
For example, using 1st order upwind instead of a higher order discretization scheme may stabilize the computation (but at the cost of accuracy). Sometimes first solving the problem in 1st order, and switching to 2nd order once the first order solution converged helps (although it may still diverge then - it's not a magic solution).
Hope that helps!
Good luck,
Cees
CeesH is offline   Reply With Quote
Old   February 1, 2015, 04:31
adam
thank u very much, Cees. I have tried all these possibilities but the divergence is still happening.
Old   February 1, 2015, 08:44
adam
Hallo Cees; apparently with change of mesh density it works (with much longer time), but it works.
So thank u a lot for ur advices.
Floating Point Exception Error nyox FLUENT 11 November 30, 2018 12:31
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
Divergence problem Smaras FLUENT 13 February 21, 2013 05:03
3d vof Smaras FLUENT 2 February 19, 2013 06:58
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
