Fluent 14.0 file not running in parallel mode in cluster
Old   February 4, 2015, 07:02
Default Fluent 14.0 file not running in parallel mode in cluster
Tej
tejakalva is on a distinguished road
I have created a fluent 14.0 file to be run in cluster. When I give the series command the file is running in 1 core but when I give the parallel command also the file is running only in 1 core. The cluster is allocating 8 cores but the file is running only in 1 core. Below are the PBS scripts and journal files.
PBS Parallel
#! /bin/bash
#PBS -o logfile1.log
#PBS -e errorfile1.err
#PBS -l cput=740:00:00
#PBS -l select=1:ncpus=8
tpdir=`echo $PBS_JOBID | cut -f 1 -d .`
tempdir=$HOME/work/job$tpdir
mkdir -p $tempdir
cd $tempdir
cp -R $PBS_O_WORKDIR/* .
fluent 3ddp -g –t8 -pib -cnf=$PBS_NODEFILE -ssh -i srik1.jou >> out
mv ../job$tpdir $PBS_O_WORKDIR/.
PBS Serial
#! /bin/bash
#PBS -o logfile2.log
#PBS -e errorfile2.err
#PBS -l cput=500:00:00
#PBS -l select=1:ncpus=1
mkdir -p $tempdir
cd $tempdir
fluent 3ddp -g -i srik1.jou
Journal File
/file/rcd case_0.5.cas
/solve/set/time-step 0.1
/solve/dual-time-iterate 80000 50
/file/wcd casefinal
/exit/yes
Licenses are availbale on the cluster on all the nodes and cores but my file is not running in all the cores even when I am submitting it in the parallel mode command. Please help me out as I dont know why it is running only in one core and not all the 8 cores?
tejakalva is offline   Reply With Quote
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 17:25
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 18:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 07:18
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
