Impose a boundary condition on an interface between a solid and a fluid
Old   February 10, 2015, 12:37
Default Impose a boundary condition on an interface between a solid and a fluid
ajdad
ajdad is on a distinguished road
I seek to impose a boundary condition on an interface between a solid and a fluid ???
plzzz help me
ajdad is offline   Reply With Quote
Old   February 11, 2015, 03:09
Cees Haringa
CeesH is on a distinguished road
I Guess a solid-fluid interface would simply be a wall? What is the problem with applying a boundary condition there?
Or are you using a solid zone and fluid zone? If so - why; why not just leave out the solid part, and make the interfaces walls?
CeesH is offline   Reply With Quote
Old   February 11, 2015, 11:34
ajdad
thank you CeesH for your reply, I explain my problem:
I want to simulate a solar receiver. we have two coaxial tubes.
the inner tube of length = 3m, it is made of steel it has a thickness = 3mm and receives a solar flux = 8000 W.
the outer tube is made of glass.
==> Be simulated, the convective thermal exchanges between the internal tube and the area of the cavity ???
When I use ansys fluent, I find the problem of creating a shadow face of the outer face of the inner tube, which I must impose a condition (flux = 8000W) !!!
Is what I will impose the boundary condition on the outer surface of the tube or on shadow face ???
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
