February 15, 2015, 16:12 |
Grid and time step independence study
navid
Rep Power: 16 |
Hi All,
I have a rather simple though important question. I am doing an unsteady analysis of a compressible flow using coupled pressure-based solver (The reason I use pressure-base is I have to use VOF method which is not compatible with density-base solver). My main question is how can I do a reliable mesh size and time step size independence study so that I can make sure my results will not change further significantly? Here is what I think: 1) Shall I first fix time step and refine grid. Then when the results are almost independent, refine the time step on that grid to find the desired time step? 2) Or shall I use a fix CFL number for the flow (such as 0.25), and based on CFL= velocity of sound*dt/dx and a grid size (dx), find the time step and do a simulation. Then by keeping CFL the same (0.25), half the grid size (therefore the time step should be half) and do another simulation and compare the results? Is there another method too? Are both the 1st and 2nd methods I mentioned above correct? |
February 16, 2015, 12:03 |
navid
Rep Power: 16 |
Let me make my question more clear:
How do you guys usually do grid and time step size study for an unsteady flow? what is the correct procedure for that? |
February 16, 2015, 13:50 |
#3 | |
Lucky
Rep Power: 66 |
1a) Fix the time-step, refine the grid. 1b) Fix the grid, refine the time-step. That is, half the time-step on your original grid. 2) refine both grid and time-step, keeping Courant number the same 1a) allows you to quantify the grid sensitivity 1b) allows you to quantify the time-step sensitivity 2) allows you to quantify both Unless you are specifically interested in what is the grid's contribution and what is the time-step contribution to your sensitivity, you do not need to do 1a & 1b. Hence, I always do 2. 2) captures both grid and time-step sensitivity, but does not allow you to distinguish how much sensitivity came from where. If you just want overall sensitivity, doing 2) is sufficient. |
February 16, 2015, 16:21 |
navid
Rep Power: 16 |
Thanks LuckyTran for your reply.
Is there a way to find what courant number should be used in method 2? I am using 0.25 but if you have a high speed computer I think the smaller the courant number, the better the result. What is your idea? Is it reasonable (or do people usually do it) to compare several courant numbers together such as 0.75, 0.5, 0.25 and report the results based on that?or you can just pick a arbitrary courant number and do the grid and time step study? |
February 16, 2015, 16:40 |
#5 | |
Lucky
Rep Power: 66 |
What is truly important in transient/unsteady simulations is the time-step size relative to the time-scale of the phenomenon. Unfortunately Courant number entangles that with an arbitrary length scale. That is, Courant number is more closely related to a length scale (the grid size) than the characteristic time-scales of the flow. |
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 03:33 |
courant number in vof | reza_gharib1369 | FLUENT | 49 | February 26, 2020 16:55 |
grid independence and time step independence in VOF computation | yhy20081016 | FLUENT | 0 | July 6, 2014 06:42 |
interDyMFoam in parallel | idefix | OpenFOAM Running, Solving & CFD | 0 | May 21, 2013 02:34 |
time step and grid convergence | ojha.mayank485 | CFX | 1 | May 3, 2011 19:04 |
