Perturbation to a Steady State Solution, how to?
Old   February 16, 2015, 05:56
Default Perturbation to a Steady State Solution, how to?
Ashwin N
ash_n is on a distinguished road
Hey all!
So I am modelling a simple Laminar 2D Pipe flow in Fluent, (which I am new to btw). So, once I solve for the transient case for a certain timesteps and I get more or less a steady state solution, I want to introduce a pressure perturbation at the inlet and wanna gauge the response of the fluid. How can I go about doing this in Fluent?
Kindly suggest a simple method for this.
Regards.
ash_n is offline   Reply With Quote
Old   October 17, 2017, 06:46
Default introducing a perturbation
Rohit
rohitkjohn is on a distinguished road
If you want to introduce a perturbation by changing the boundary condition, I would suggest you use a UDF. The following is a code which you can save as a .c file and compile in FLUENT
/* the following UDF imposes a value of pressure p0 at the required boundary before time t1. Once t1 is crossed the this a perturbation is introduced in the form
of an increased pressure, p1, at the boundary. This is done using an if-else condition
#include "udf.h"
DEFINE_PROFILE(unsteady_pressure, thread, position)
face_t f;
real t = CURRENT_TIME;
real t1 = 0.1; /*The time after which you want to add the perturbation*/
real p0 = 200; /*This is the initial pressure you impose at the boundary*/
real p1 = 210; /*This the perturbed value of pressure*/
begin_f_loop(f, thread)
if(t<t1)
F_PROFILE(f, thread, position) = p0;
else
F_PROFILE(f, thread, position) = p1;
end_f_loop(f, thread)
rohitkjohn is offline   Reply With Quote
Old   October 17, 2017, 06:47
Rohit
you may search online how to add a UDF to FLUENT
oscillations, perturbation, response
Solidification modelling-Continuous Casting- Steady State. lucky_m_m FLUENT 1 June 8, 2022 22:23
The difference between steady state and transient JuPa CFX 36 December 9, 2019 22:50
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Solver for transonic flow? Martin Hegedus OpenFOAM Running, Solving & CFD 22 December 16, 2015 04:59
Steady State 2 phase problem fivos FLUENT 0 April 27, 2009 16:34
