Velocity profile reading in Fluent
Old   July 28, 2016, 02:12
Default Velocity profile reading in Fluent
mkpm
mkpm is on a distinguished road
Hi
I just wanted to implement fully developed velocity profile at the inlet of a 3D model(say A). so i did simulate another 3D model (say B) and exported the profile file from its outlet which contains velocity magnitude, x y z velocity components and successfully read at the inlet of model A (used interpolations such as constant, inverse distance). The problem which i face is that the velocity value does not match, ie at the outlet of model B, velocity is 3,but after reading profile at the inlet of model A, velocity is 2.05.What could be the reason? Kindly help
FYKI
I could implement fully developed velocity profile at the inlet of model A, but with incorrect velocity at inlet. Both models have same dimensions
mkpm is offline   Reply With Quote
velocity profile
fluent velocity profile input ashfak.iitd FLUENT 0 July 20, 2016 15:46
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 06:37
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
Drawing a velocity profile as inlet boundary condition in Fluent ANSYS ???? hasanifte FLUENT 2 February 18, 2015 12:44
Fluent does not recognize my UDF for velocity profile salihovic Fluent UDF and Scheme Programming 1 September 10, 2012 06:27
